Author Topic: Whats difference between ...?  (Read 5767 times)
HasanCAD
« on: July 08, 2010, 06:46:45 AM »
(defun c:test [color=red]()[/color]
(defun c:test[color=red](/)[/color]
(defun c:test [color=red](/ var1 var2)[/color]
and
(defun c:test [color=red](var1 / var2)[/color]
Up to my little knowladge
First case will not reset the variables value when code finished.
Third case will reset the variables value when code finished.
Krushert
  • FREE BEER Tomorrow!!
Re: Whats difference between ...?
« Reply #1 on: July 08, 2010, 07:27:47 AM »
Good Question
TimSpangler
  • CAD Naked!!
« Reply #2 on: July 08, 2010, 07:45:58 AM »
1 and 2 are the same
3 you are localizing 2 variables  var1 and var2
4 you are passing and argument  var1  (it really should read arg1)  and localizing a variable var2
-essentially you are giving the routine some information to work with
HTH
ACA 2015 - Windows 7 Pro
Krushert
« Reply #3 on: July 08, 2010, 08:10:03 AM »
Thanks.  But this leads to another question.
IN layman terms, What is an argument?  And when and why should I use them?
« Reply #4 on: July 08, 2010, 08:12:20 AM »
Quick Example of Argument passing/localising variables:
(defun c:test ( / num )
  (if (setq num (getint "\nPick a Number: "))
    (doit num)
(defun doit ( n / str )
  (setq str (strcat "You chose the number: " (itoa n)))
  (alert str)
Notice how the variable 'num' is passed as an argument to the function 'doit'. The data bound to the symbol 'num' is then bound to the symbol 'n' and can be manipulated by the 'doit' function.
Notice also that the variables 'str' and 'num' are localised in their respective functions.
Lee
TimSpangler
  • CAD Naked!!
« Reply #5 on: July 08, 2010, 08:14:20 AM »
You would use an argument when you want to give the sub some information to process;
(defun add ( n1 /)
(+ 10 n1)
In that example you would pass a integer to the sub to be added to 10
(add 30)
should return 40
There were no variables needed in that example.
Krushert
« Reply #6 on: July 08, 2010, 08:44:04 AM »
I am still foggy on the issue.  I (in my limited lisp writing knowledge) would write it this way:
(defun c:test (/ num str)
  (setq str (strcat "You chose the number: " (itoa num)))
  (alert str)
Thus no need for an agument.  I know lisp writing can be done many different ways but I am trying to see the benefit because there has to be at least one if you guys are using them.
And how did sub get the information?  I do not see the variable num in the sub thus making the link.
« Reply #7 on: July 08, 2010, 08:49:53 AM »
The 'link' is in passing the data to the subfunction via the argument - the symbol 'n' in my example is the argument and the data is bound to it when the subfunction is called.
As for why, perhaps consider how you would rewrite this example:
(defun c:test nil
  (mapcar 'dtr (list 0.0 45.0 90.0 135.0 180.0))
(defun dtr ( a )
  (* pi (/ a 180.0))
TimSpangler
  • CAD Naked!!
« Reply #8 on: July 08, 2010, 08:58:10 AM »
Lets look at the degrees to radians function
(defun DTR (numberOfDegrees)
 (* pi (/ numberOfDegrees 180.0))
When you need to convert degrees to radians in one of your functions you make a call to this function.  You would need to pass that function an argument (in this case degrees).  In turn this function would return the number of radians in the supplied degrees.  So it gets the info from the programmer of from another function in your program.
This is used when you have to do a lot of converting.  It will cut down the amount of code needed by creating a sub to handle the conversion rather than typing this everytime you need to convert:
(setq rads (* pi (/ "yourdegreeshere" 180.0)))
it would be like this instead
(setq rads (DTR "yourdegreeshere"))
I an horrible at explaining this sort of thing.  Sorry. :|
TimSpangler
  • CAD Naked!!
« Reply #9 on: July 08, 2010, 08:58:49 AM »
That is funny that we used the same code as an example........ :lol:
« Reply #10 on: July 08, 2010, 08:59:52 AM »
I was just thinking the same thing...  :lol:
« Reply #11 on: July 08, 2010, 09:10:07 AM »
Perhaps also look at the help on 'defun' and:
Using the AutoLISP Language > AutoLISP Basics > Symbol and Function Handling > Functions with Arguments
Krushert
« Reply #12 on: July 08, 2010, 09:36:50 AM »
Sorry Lee I am still not seeing the link in you DTR example.  I can in Tim's and in autocads help - sort-of.  How is "a" getting it data.   Furthermore (and this is embarrassing) I have never needed the DTR and RTD functions.  I have one lisp that uses rads and I left it processing the rads. Degrees were not needed becuase it would be irrelevant processing that the user would never see.  Draw a line at this angle, period.
  (setq ANG1 (angle UP1 UP2))
  (setq ANG2 (angle UP2 UP3))
 I use sub functions but more to grope my code in chunks.  Really not needed but it makes sense to me.
What is even more embarrassing is that I have never needed to process a list.  Unless it was in a fish that was thrown to me.
So asking me to rewrite your example that would be a class in itself.  :oops:
Krushert
« Reply #13 on: July 08, 2010, 09:42:15 AM »
I will.
Thanks.
« Reply #14 on: July 08, 2010, 09:44:21 AM »
Ok, perhaps 'mapcar' was a bad example (I'm also not too good at explaining this stuff...) this is perhaps a better example:
Consider the function 'angle', this function takes two arguments - two points, and returns the angle between them.
What we are effectively doing is creating our own 'library functions' taking arguments just as functions such as 'angle' etc do.
In our previous examples, the 'dtr' function takes one argument (a real number) and returns a real number. (I too don't use degrees all too often - don't worry about it).
(defun dtr ( a )
  (* pi (/ a 180.0))
Here, 'a' represents the argument (real number) that the user needs to provide in order to use the function.
Hence just as we do this:
(angle <pt1> <pt2>)
We can do this:
(dtr <real>)
« Last Edit: July 08, 2010, 09:47:23 AM by Lee Mac »
