Author Topic: Whats difference between ...?  (Read 5774 times)
TimSpangler
  • CAD Naked!!
Re: Whats difference between ...?
« Reply #16 on: July 08, 2010, 10:29:31 AM »
How is "a" getting it data.
  (setq ANG1 (angle UP1 UP2))
  (setq ANG2 (angle UP2 UP3))
 I use sub functions but more to grope my code in chunks.  Really not needed but it makes sense to me.
"a" is gotten from you or the program itself.  Take your example
(setq a (angle UP1 UP2));; This sets "a"
 (setq d (RTD a));; This calls RTD and sends "a" as an argument. It converts "a" and sets "d" to the conversion.
(defun RTD (Rads /)
 (* 180.0 (/ Rads pi))
ACA 2015 - Windows 7 Pro
hermanm
« Reply #17 on: July 08, 2010, 10:41:48 AM »
1 and 2 are the same
3 you are localizing 2 variables  var1 and var2
4 you are passing and argument  var1  (it really should read arg1)  and localizing a variable var2
-essentially you are giving the routine some information to work with
HTH
Tim, you probably already know this , but for anyone who does not,
The arguments (sometimes called parameters in the function definition) also become local variables (local symbols) to the function.
So, you can do this:
(contrived ridiculous example)
Command: (defun foo ( a / ) (setq a (+ 5 a)) (princ (itoa a)))
FOO
Command: (foo 12)
17"17"
Meaning, if you need to process an argument in some way, then do multiple things with the modified value, you need not define a local symbol to hold the modified value, because the argument is itself a local symbol.
If you don't know where you are going, you might not get there.
  - L.P. Berra
TimSpangler
  • CAD Naked!!
« Reply #18 on: July 08, 2010, 11:03:56 AM »
I think the example was a good one.  :-)
I would have gone with a bit less:
Command: (defun foo ( a / ) (setq a (+ 5 a)))
FOO
Command: (foo 12)
17
I didn't see the need to convert the value.   :-P (just having a slow day, don't mind me)
dgorsman
« Reply #19 on: July 08, 2010, 11:38:14 AM »
A more concrete example would be taking a folder path as a string.  If the function is expecting a trailing "\\" at the end, the argument can be checked and modified if necessary without having to track a separate variable.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
