Author Topic: AutoCAD .NET Wizard  (Read 5154 times)
Glenn R
AutoCAD .NET Wizard
« on: September 16, 2009, 04:10:27 AM »
Kean's got this up on his blog. Has anybody installed it? I tried and it said it would install to:
C:\Program Files\Autodesk\AutoCAD 2010 Wizard or somesuch (can't remember the exact path), but upon looking it's not there.
Box has Visual C# 2008 Express on it and the Wizard is present when creating a new project. Another Thing I've noticed is that the wizrd asks for the SDK location which I pointed to 2008 SDK.
After project creation, I looked in the references and AcDbMgd etc are there, but they can't be found....some sort of pathing problem....? Maybe they expect you to add the SDK location to the system path...?
Anybody else experienced this?
It's Alive!
  • Retired
  • AKA Daniel
Re: AutoCAD .NET Wizard
« Reply #1 on: September 16, 2009, 04:32:06 AM »
Works here, it asked me for the Arx SDK path and all the references came through
Glenn R
« Reply #2 on: September 16, 2009, 06:32:20 AM »
Can you find the install folder Dan?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: September 16, 2009, 06:39:43 AM »
C:\Program Files (x86)\Autodesk\
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: September 16, 2009, 06:41:25 AM »
wait!
Glenn R
« Reply #5 on: September 16, 2009, 06:47:46 AM »
Waiting...
« Reply #6 on: September 16, 2009, 06:48:07 AM »
C:\Program Files\Autodesk\AutoCAD 2010 .NET Wizards\
Glenn R
« Reply #7 on: September 16, 2009, 06:50:20 AM »
That's where it was supposed to go, but there's nothing there...
Thanks Kerry.
« Reply #8 on: September 16, 2009, 06:56:17 AM »
How about ..
C:\Documents and Settings\<ThelOldBlokeInTheCorner>\Application Data\Autodesk\ObjectARX Wizards for AutoCAD 2010\settings.xml
Glenn R
« Reply #9 on: September 16, 2009, 07:10:22 AM »
Spotted that settings file as well Kerry...
« Reply #10 on: September 16, 2009, 07:13:13 AM »
A Piccy ..
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: September 16, 2009, 07:15:58 AM »
Thanks Kerry!!!
I was looking at the old path  :oops:
Glenn R
« Reply #12 on: September 16, 2009, 07:18:35 AM »
Kerry,
I have a ProjectTemplatesCache folder under VCSExpress, but no Visual C# forlder or wizrd.zip
« Reply #13 on: September 16, 2009, 07:19:14 AM »
Glenn,
Does the 2008 SDK have the .NET dll's in the ..\inc folder ??
« Reply #14 on: September 16, 2009, 07:24:12 AM »
do you have anything under
..\MyDocuments\Visual Studio 2008\Templates\ProjectTemplates\Visual C#\....
I seem to recall that express was different to pro ... but I'm affected by oldtimers an a couple of glasses of wine :)
