Author Topic: AutoCAD .NET Wizard  (Read 5100 times)
Re: AutoCAD .NET Wizard
« Reply #15 on: September 16, 2009, 07:25:39 AM »
Seems that a note to Fenton or Kean is in order
... " documentation Required"   :roll:
Glenn R
« Reply #16 on: September 16, 2009, 03:45:58 PM »
do you have anything under
..\MyDocuments\Visual Studio 2008\Templates\ProjectTemplates\Visual C#\....
I seem to recall that express was different to pro ... but I'm affected by oldtimers an a couple of glasses of wine :)
Nothing under that, as I don't have full Vis Stud installed at the moment.
Glenn R
« Reply #17 on: September 16, 2009, 03:46:41 PM »
Glenn,
Does the 2008 SDK have the .NET dll's in the ..\inc folder ??
Certainly does mate...thought I was going mad.
