Author Topic: Dynamic Intelligent Leader !  (Read 183505 times)
Gilles
Re: Dynamic Intelligent Leader !
« Reply #270 on: June 02, 2010, 12:47:04 PM »
Cool, Andrea.
Beautiful lisp.
I see a lot of aplications in what I do. :lol:
But one thing bothers me, I have not found how to impose a distance between objects created!
Is it possible and how should I do?
Thank you for your explanations.
Postscript: I am really no English  :realmad:
Gilles
« Reply #271 on: June 02, 2010, 12:52:25 PM »
Sorry, I was wrong post.
I wanted to talk about Darray :oops:
RGUS
« Reply #272 on: June 02, 2010, 02:52:45 PM »
Really quite amazing... you been offered a job at AutoDesk yet... and why not!! LOL
Andrea
« Reply #273 on: June 02, 2010, 03:14:02 PM »
Cool, Andrea.
Beautiful lisp.
Hi Gilles..
I've never tought about that..
but it is a good idea....i'll add it on next release.
thanks.
Ca sera ajouté à la prochaine version.
merci pour cette idée.
Keep smile...
Andrea
« Reply #274 on: June 02, 2010, 03:16:31 PM »
thanks RGUS...
I think I have anough job.... LOL !
Keep smile...
Gilles
« Reply #275 on: June 04, 2010, 01:45:36 PM »
Hi Andrea,
J'ai des difficultés pour faire fonctionner DiLeader correctement.
Sous dilconfig, j'ai un message d'erreur à la validation:
"Commande: dilconfig
Demande ADS erronée
type d'argument incorrect: fixnump: nil1"
J'utise la v2.3.0, mais 2.2.8 est affiché!
Où est le problème?
I have difficulty operating properly DiLeader.
Under dilconfig, I get an error at validation:
Demande ADS erronée
I use the v2.3.0 but 2.2.8 is available!
Where is the problem?
Andrea
« Reply #276 on: June 04, 2010, 11:08:43 PM »
Hi Andrea,
Demande ADS erronée
Où est le problème?
Demande ADS erronée
Ok Gilles,...what version of autoCAD are you using ?
is that error message is present in any drawings ?
Keep smile...
Gilles
« Reply #277 on: June 05, 2010, 03:31:17 AM »
I use autoCAD 2009
Yes, this error message is present in every drawings.
Gilles
« Reply #278 on: June 12, 2010, 06:07:23 AM »
Bonjour à tous.
J'ai désinstallé la v2.3.0, redémarré l'ordinateur et réinstallé v2.3.0.
Le lisp ne se charge plus du tout. :-(
Copie d'écran:
Hello everyone.
I uninstalled the v2.3.0, rebooted the computer and reinstalled v2.3.0.
The lisp is not charging anymore. :-(
Screenshot:
Merci de m'aider.
Thank you for helping me.
Andrea
« Reply #279 on: June 12, 2010, 03:00:27 PM »
Salut Gilles..
s.v.p. vérifie ton fichier DLCONFIG,CFG, il doit resembler a ceci:
Le message d'erreur semble dire qu'il n'y a aucune valeur sous "Leader GAP Y..."
;Mask type 0=none 1=Wipeout
0
;Multi-Selection 0=No 1=Yes
0
;+ or - Key for Arrow size is activation 0=No 1=Yes
1
;Convert Qleader to DiLEADER 0=No 1=Yes
1
;Language
Francais
;Convert DiLEADER to annotative object
0
;Custom Arrow Path
C:\test_dessins\leadersarrow
;Use default 0=Text or 1=Mtext
0
;Auto-Numbering
(1 "" 1 "" "A" "A" "+" "1" 1)
;Leader end Length
0
;Leader Gap X axis
0
;Leader Gap Y axis
0
Please check your DLCONFIG.CFG file. it must contain someting similar of this.
The error message seem that you have no value on Leader GAP on Y axis.
Could you confirm ?
Merci.
Keep smile...
Gilles
« Reply #280 on: June 13, 2010, 04:48:35 AM »
Salut Andrea.
J'ai remplacé le fichier config par celui que tu viens de donner car il était différent. Je mets l'ancien en pièce jointe.
Le lisp ne fonctionne toujours pas, mais le message d'erreur n'est plus le même.
Copie d'écran.
Hi Andrea.
I replaced the config file that you just give because it was different. I put the old in attachment.
The Lisp does not work, but the error message is no longer the same.
Screenshot attached.
Andrea
« Reply #281 on: June 13, 2010, 10:28:02 AM »
Salut Gilles,..
Could you give this a try ?
Keep smile...
Gilles
« Reply #282 on: June 14, 2010, 04:43:40 AM »
Salut Andrea.
Désolé, çà marche pas.
Message en ligne de commande:
Commande: appload
dileader2.3.1.LSP correctement chargé(s)
Commande:
DiLEADER version v.2.3.0 par: Andrea Andreetti
type d'argument incorrect: stringp nil
Commande:
Commande: dil
Commande inconnue "DIL".  Appuyez sur F1 pour obtenir de l'aide.
J'ai remplacé dileader2.3.0.lsp par dileader2.3.1.lsp dans le dossier C:\Program Files\DuctiSoft\DiLeader2.3.0
Testé aussi avec dileader2.3.1.lsp seul sur le bureau.
J'ai dans tous les cas le message cité plus haut. :|
Andrea, je suis désolé pour ces complications.... :|
Suis-je le seul à avoir ce problème?
Hi Andrea.
Sorry, not work here.
Message command line:
Commande: appload
Commande:
Commande:
Commande: dil
I replaced dileader2.3.0.lsp by dileader2.3.1.lsp in the C:\Program Files\DuctiSoft\DiLeader2.3.0
Tested also with dileader2.3.1.lsp alone on the desktop.
I have in all cases the message quoted above.
Andrea, I am sorry for these complications .... :|
Am I the only one having this problem?
Hugo
« Reply #283 on: June 14, 2010, 04:49:56 AM »
@Gilles
No, I feel the same way.
Nein geht mir genauso.
Gilles
« Reply #284 on: June 14, 2010, 05:04:51 AM »
Bonjour Hugo.
Tu me rassures. :-P
Hello Hugo.
You reassure me.
