Author Topic: Dynamic Intelligent Leader !  (Read 182749 times)
Andrea
Re: Dynamic Intelligent Leader !
« Reply #255 on: January 13, 2010, 06:28:53 PM »
How easy it is to create Leader and identify multiple object with DiLeader.. :roll:
But...
How easy it is to Align all these Leader to provide Good quality Drawing ?   :realmad:
Easy as DiLAlign....
Comming Soon on Future release...  :kewl:
Keep smile...
« Reply #256 on: January 13, 2010, 06:36:32 PM »
Nice idea!  :-)
Andrea
« Reply #257 on: January 14, 2010, 08:36:42 AM »
thanks Lee...
I was inspired by this
Keep smile...
Andrea
« Reply #258 on: January 18, 2010, 05:38:24 PM »
There we Go..
DiLEADER 2.3.0
Bug Fix:
  • Previous selection
New Commands and/or Options:
  • DilFSL, DilGAPx, DilGAPy command allow now to adjust the first line location from the text.
  • DiLalign command allow user to aline all Leader created with DiLeader. (shift key is used to aline on Y axis)
    some Gif.
    Enjoy !
« Last Edit: January 18, 2010, 05:42:14 PM by Andrea »
Keep smile...
Aerdvark
« Reply #259 on: January 19, 2010, 02:13:05 AM »
Andrea,
Am I doing something wrong??
Command: appload
dileader2.3.0.LSP successfully loaded.
Command: ;Mask type 0=none 1=Wipeout
0
;Multi-Selection 0=No 1=Yes
0
;+ or - Key for Arrow size is activation 0=No 1=Yes
1
;Convert Qleader to DiLEADER 0=No 1=Yes
1
;Language
English
;Convert DiLEADER to annotative object
0
;Custom Arrow Path
;Use default 0=Text or 1=Mtext
0
;Auto-Numbering
(1 "pref" 0 "suff" "1" "48" "x" "1" 1)
;Leader end Length
0
;Leader Gap X axis
0
;Leader Gap Y axis
; error: bad argument type: streamp nil
Command:
All I did is load it.... Maybe a little, tiny, problem / bug?
Hugo
« Reply #260 on: January 19, 2010, 04:07:54 AM »
Hallo Andrea
Do not know what I am doing wrong
Command: dilalgin
Unknown command "DILALGIN".  Press F1 for help.
« Reply #261 on: January 19, 2010, 04:12:35 AM »
Hallo Andrea
Command: dilalgin
Looks like you are spelling it wrong: DILALIGN
Hugo
« Reply #262 on: January 19, 2010, 04:20:19 AM »
Thanks MAC
I have completely overlooked
Sorry
Hugo
« Reply #263 on: January 19, 2010, 05:07:36 AM »
Hallo Andrea
And what has it here
Befehl: dilconfig
no function definition: Odcl_LoadProject
Aerdvark
« Reply #264 on: January 19, 2010, 05:53:08 AM »
Does one need to install object dcl?
Hugo
« Reply #265 on: January 19, 2010, 06:00:32 AM »
What I have just invite you to explain it to me please.
RIOGHAN
« Reply #266 on: January 19, 2010, 07:56:27 AM »
Andrea,
The higher ups here have decided that we need administrative priviledges to install things on our "Program Files" folder.  Would you be able to change your zip file so that I can browse for a folder to put in?
« Reply #267 on: January 19, 2010, 08:58:41 AM »
Andrea,
You did not say what the minimum requirements were.
What ACAD version is required to run this routine?
Andrea
« Reply #268 on: January 19, 2010, 11:50:43 AM »
Well you'r right..
I miss to explain how to install..sorry for that.
attached on this post, a ZIP file containing all necessary files
that need to be extracted to c:\program files\ductisoft\DiLeader\
LSP = file source to load in autoCAD
VLX = compiled LSP file automaticly loaded by LSP.
mht = Help files
cfg = configuration of DiLeader settings.
ods = Dialog file can be viewed only if ObjectDCL is installed.
Kds = signature file allowing to view the Dialog without activate ObjectDCL.
lpk = Language Pack file can be edited using notepad.
gif = animated Gif file required when about button is pressed.
Required:
but don't forget that the dialog is only an interface who change only some parameter in CFG file
that can also be edited with notepad.
Tested on AutoCAD 2006 -> 2010
the exe file is an self extractor created with WinRaR who will extract all file in the specific folder
and start the "thanks.mht" file after the extraction to explain how it work.
I work a lot to create 2 help files  (english and French) with screenShot and animated Gif.
Please don'T be shy to ask any questions...
thanks.
« Last Edit: January 02, 2013, 08:44:57 PM by Andrea »
Keep smile...
KewlToyZ
« Reply #269 on: February 09, 2010, 07:28:32 PM »
Thanks Andrea  ;-)
