Author Topic: remove elements from a list with identifier of sub-list (recursive)  (Read 11614 times)
robertocuba
Hello:
Iīm developing a following routine to remove elements from a list between identifiers "x" .... "x" of sub-list (recursive).
Problem:
List: ("a" 3 4 5 5 "b" 8 7 6 3 2 2 1 1 "c" 5 67 87 76 "d" 9 0 5 49 5 9)
The routine must be return:
List:  ("a" 3 4 5 "b" 8 7 6 3 2 1 "c" 5 67 87 76 "d" 9 0 5 49)
Thanks !
Re: remove elements from a list with identifier of sub-list (recursive)
« Reply #1 on: June 08, 2009, 01:42:22 PM »
Post the code you've developed so far.
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
uncoolperson
« Reply #2 on: June 08, 2009, 02:49:50 PM »
from your example I'm having trouble understanding what you want to remove.
in three instances duplicated items have one removed
then there's the items at the end that are removed
robertocuba
« Reply #3 on: June 08, 2009, 03:00:06 PM »
Yes, I want remove the similar elements, between "a" and "b", and between "b" and " and ...
« Reply #4 on: June 08, 2009, 03:01:45 PM »
It appears to me that alpha characters are delimiters, anything before, between or after are subgroups, and the OP's want is to have each subgroup sport unique members. I'm getting a strong impression these exercises are actually homework assignments, and as much as I enjoy challenges, I have no interest if they are indeed homework. Of course I'm open to hearing an alternative explanation and viewing the OP's attempts thus far.
uncoolperson
« Reply #5 on: June 08, 2009, 03:46:18 PM »
it was fun solving though.
« Reply #6 on: June 08, 2009, 03:53:23 PM »
Agreed.
Mine's a bit verbose at 14 lines.
« Last Edit: June 08, 2009, 04:02:25 PM by MP »
uncoolperson
« Reply #7 on: June 08, 2009, 04:14:13 PM »
3 recursives, not very streamlined... way too many lines that look similar and are begging to be condensed. it was fun to think through.
gile
  • Marseille, France
« Reply #8 on: June 08, 2009, 04:51:13 PM »
14 lines too (vlisp formated), only one recursive sub
« Reply #9 on: June 08, 2009, 05:01:17 PM »
Ummm...*Se7en: scratches head* ...why recursive?
And if this is homework then; `recursive' describes the procedure not necessarily the type of process. So what kind of process? -i.e. you want a ``Recursive procedure using a ______ process which will remove the elements....''?
gile
  • Marseille, France
« Reply #10 on: June 08, 2009, 05:16:31 PM »
11 lines, but need to call (foo lst nil)
uncoolperson
« Reply #11 on: June 08, 2009, 05:30:48 PM »
you know I've never understood counting lines in lisp.
I mean in theory mine could be 3 lines.
(sorry, just trying to make me feel better about myself)
« Reply #12 on: June 08, 2009, 05:34:54 PM »
<snip>
<snip>
In theory,  it could be one. *lol*
« Reply #13 on: June 08, 2009, 06:00:25 PM »
Bizarro world: same here but 12 lines, 15 with the wrapper. :D
1 line if I skip the superfluous carriage returns.  :-D
robertocuba
« Reply #14 on: June 08, 2009, 06:17:13 PM »
The code?
Thanks !
