Author Topic: remove elements from a list with identifier of sub-list (recursive)  (Read 11414 times)
Re: remove elements from a list with identifier of sub-list (recursive)
« Reply #15 on: June 08, 2009, 06:17:57 PM »
You post your attempts first robertocuba . :evil:
uncoolperson
« Reply #16 on: June 08, 2009, 06:27:50 PM »
single recursive function containing two if statements, one of those empty list check, the other one an "(and".
requires reversal of list prior to use
heck yeah.
robertocuba, hurry up and post some stuff, I wanna show this off.
robertocuba
« Reply #17 on: June 08, 2009, 06:32:53 PM »
This is my first code:
(defun remove_doubles (lst)
  (if lst
    (cons (car lst) (remove_doubles (vl-remove (car lst) lst)))
(defun process_list (list_p / contador centinel element lista_tmp list_final)
  (setq contador 0)
  (while (< contador (length list_p))
      (setq centinel 0)
      (setq element (nth contador list_p))
      (if (= nil (numberp element))
     (setq lista_tmp (cons (nth contador list_p) lista_tmp))
     (while (= centinel 0)
       (if (= T (numberp (nth (+ contador 1) list_p)))
         (setq lista_tmp (cons (nth (+ contador 1) list_p) lista_tmp))
         ;else
      (setq list_final (cons (remove_doubles lista_tmp) list_final))
           (setq centinel 1)
       (setq contador (+ contador 1))
(defun c:x ()
    (setq l (process_list '("m1-1" 1 2 "m1-2" 3 3 4 "m1-3" 1 1 1 2 2 3)))
« Reply #18 on: June 08, 2009, 06:33:14 PM »
Not pretty but it works and is faster than my other attempts ...
(defun foo ( lst / bar )
    (defun bar ( a b / c e )
        (if a
            (bar
                (cdr a)
                (if (eq 'str (type (setq e (car a))))
                    (cons (list e) b)
                    (if (member e (setq c (car b))) b (cons (cons e c) (cdr b)))
            (apply 'append (reverse (mapcar 'reverse b)))
    (bar lst nil)
robertocuba
« Reply #19 on: June 08, 2009, 06:35:51 PM »
Excellent !
« Reply #20 on: June 08, 2009, 06:36:51 PM »
Don't get too excited, mine's likely the least elegant of them all. Stay tuned ... :)
« Reply #21 on: June 08, 2009, 06:41:48 PM »
Here's one of my other stabs:
    (defun bar ( a b c / e f )
        (if a
            (bar
                (cdr a)
                (if (setq f (eq 'str (type (setq e (car a)))))
                    (list e)
                    (if (member e b) b (cons e b))
                (if f (cons b c) c)
            (apply 'append (reverse (mapcar 'reverse (cons b c))))
    (bar lst nil nil)
uncoolperson
« Reply #22 on: June 08, 2009, 06:53:07 PM »
(defun doit (thelist)
  (reverse (remove (reverse thelist)))
(defun remove (alist)
  (if alist
      (and
                (/= (type (car alist)) 'STR)
                (> (length (member (car alist) (cdr alist)))
                   (length
                     (vl-member-if '(lambda (item) (= (type item) 'STR)) alist)
       (remove (cdr alist))
       (cons (car alist) (remove (cdr alist)))
edit: forgot to add, there was some mild editing done without autocad around to check... so might need some minor tweaking to run. I'll check tomorrow.
« Last Edit: June 09, 2009, 12:36:15 AM by uncoolperson »
uncoolperson
« Reply #23 on: June 08, 2009, 07:14:13 PM »
        (if a
            (bar
                (cdr a)
                    (cons (list e) b)
    (bar lst nil)
I think my head just exploded with that
in the cool sorta way.
« Reply #24 on: June 08, 2009, 07:35:08 PM »
Ditto  :ugly:
Or as you say here "this".
« Reply #25 on: June 08, 2009, 09:44:10 PM »
Glad I could help. :D
Wait 'til you see Gile's.
« Reply #26 on: June 08, 2009, 11:16:12 PM »
Slight variation for fun ...
        (if (setq c (car b) e (car a))
            (bar
                (cdr a)
                (if (eq 'str (type e))
                    (cons (list e) b)
                    (if (member e c) b (cons (cons e c) (cdr b)))
    (bar lst nil)
FengK
« Reply #27 on: June 08, 2009, 11:34:12 PM »
plain. it is easier for me to follow than anything with recursion.
(defun GroupSet (lst / r subset)
  (foreach e lst
    (if (eq (type e) 'str)
      (setq r (cons e r)
      subset nil
      (if (not (member e subset))
(setq r (cons e r)
        subset (cons e subset)
  (reverse r)
uncoolperson
« Reply #28 on: June 09, 2009, 12:35:27 AM »
You never said if this was for a class or not, if it is may I suggest doing them on your own then posting the problems? As you can tell we all love a good challenge, but if it is for a class that's probably something you should work out most on your own.
gile
  • Marseille, France
« Reply #29 on: June 09, 2009, 01:34:00 AM »
 :xTime difference ! I was sleeping while you were posting
mine look like MP's
(defun foo (lst / sub)
  (defun sub (lst tmp / a)
    (if lst
      (if (numberp (setq a (car lst)))
(if (vl-position a tmp)
  (sub (cdr lst) tmp)
  (sub (cdr lst) (cons a tmp))
(append (reverse tmp) (sub (cdr lst) (list a)))
  (sub (cdr lst) (list (car lst)))
