why would the arcs be text? (they do not NEED to be text)
is it a linetype or a hatch pattern?
start with something like this:
*FENCELINE1,Fenceline circle ----0-----0----0-----0----0-----0--
A,.25,-.1,[CIRC1,ltypeshp.shx,x=-.1,s=.1],-.1,1
only you will need to create and add to the ltypeshp.shx file a(n) Arc of the desired parameters, and then call that in your linetype definition
look in help under:
In addition to defining vectors, a specification byte can use special codes to create additional forms and specify certain actions. To use a special code, the second character of the three-character string (the vector length specification) must be 0, or you can specify only the code number. For example, 008 and 8 are both valid specifications.
Codes 0, 1, and 2: End of Shape and Draw Mode Control
Codes 3 and 4: Size Control
Codes 5 and 6: Location Save/Restore
Code 7: Subshape
Codes 8 and 9: X-Y Displacements
Code 00A: Octant Arc
Code 00B: Fractional Arc
Codes 00C and 00D: Bulge-Specified Arcs
