Author Topic: Linetype is purged  (Read 10419 times)
David Hall
  • Automatic Duh Generator
Linetype is purged
« on: April 10, 2008, 03:19:44 PM »
Building on Kerry's great example of Layer code, I am trying to incorporate linetypes.
layerId = lt[layerName];
if (layerId.IsErased)
LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(layerId, OpenMode.ForWrite, true);
ltr.Erase(false);
if (ltypeId.IsErased)
   LinetypeTableRecord lttr = (LinetypeTableRecord)tr.GetObject(ltypeId, OpenMode.ForWrite, true);
   lttr.Erase(false);
   tr.Commit();
The obvious difference is I had to start a transaction, but it still crashes on lttr.erase false
Glenn R
Re: Linetype is purged
« Reply #1 on: April 10, 2008, 03:22:48 PM »
Complex linetype?
« Reply #2 on: April 10, 2008, 03:47:59 PM »
Complex linetype?
you mean the linetype has a dependency that no longer exists ??
David ,
Interesting problem ; does it happen consistantly ?
must run ,, a train to catch !
David Hall
« Reply #3 on: April 10, 2008, 03:50:35 PM »
no, just Hidden.  the problem was I had done a purge , and when I reloaded lilnetypes, it spits the dummy
David Hall
« Reply #4 on: April 10, 2008, 03:52:50 PM »
I am posting all of the code, mine at the top, Kerry's example commented out at the bottem.
using System;
using System.Data;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Colors;
using System.Diagnostics;
namespace LayerCode
    public class LayerCode
        [CommandMethod("CD3")]
        static public void createduhlayer()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
                LayerTable lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead, false) as LayerTable;
                if (lt == null)
                    return;
                if (lt.Has("DSH"))
                    return;
                LayerTableRecord newLTR = new LayerTableRecord();
                newLTR.Name = "DSH";
                newLTR.Color = Color.FromColorIndex(ColorMethod.ByAci, 2);
                // set any other properties
                lt.UpgradeOpen();
                lt.Add(newLTR);
                tr.AddNewlyCreatedDBObject(newLTR, true);
                tr.Commit();
            createLayer("Duh2");
            createLayer("Duh3", 5, "Hidden");
            //createLayerXML("Duh3");
        static public void createLayer(string Lname) //passing a Layername to function
                if (lt == null)
                    return;
                if (lt.Has(Lname))
                    return;
                newLTR.Name = Lname;
                lt.UpgradeOpen();
                lt.Add(newLTR);
                tr.Commit();
        static public void createLayer(string Lname, short ColorNum) //passing a Layername & color to function
                if (lt == null)
                    return;
                if (lt.Has(Lname))
                    return;
                newLTR.Color = Color.FromColorIndex(ColorMethod.ByAci, ColorNum);
                lt.UpgradeOpen();
                lt.Add(newLTR);
                tr.Commit();
        static public void createLayer(string Lname, short ColorNum, string LType) //passing a Layername,color,ltype to function
                if (lt == null)
                    return;
                if (lt.Has(Lname))
                    return;
                newLTR.LinetypeObjectId = GetOrLoadLinetypeId(LType, db);
                lt.UpgradeOpen();
                lt.Add(newLTR);
                tr.Commit();
        public static ObjectId GetOrLoadLinetypeId(string linetypeName, Database db)
            ObjectId ltypeId = GetSymbolTableRecId(typeof(LinetypeTableRecord), linetypeName, db);
            if (ltypeId.IsNull)
                string[] ltypeFiles;
                ltypeFiles = new string[3];
                if (db.Measurement == MeasurementValue.English)
                //if (db.Measurement == MeasurementValue.Metric)
                    PrintToCmdLine(" \n Using English Linetypes");
                    ltypeFiles[0] = "acad.lin";
                    ltypeFiles[1] = "acadiso.lin";
                    ltypeFiles[2] = "ltypeshp.lin";
                else
                    PrintToCmdLine(" \n Using Metric Linetypes");
                    ltypeFiles[0] = "acadiso.lin";
                    ltypeFiles[1] = "acad.lin";
                int len = ltypeFiles.Length;
                for (int i = 0; i < len; i++)
                    try
                        // try to load the linetype from the external file
                        db.LoadLineTypeFile(linetypeName, ltypeFiles[i]);
                                lttr.Erase (false  );
                                tr.Commit();
                        if (ltypeId.IsNull == false)
                            return ltypeId;
                    catch (Autodesk.AutoCAD.Runtime.Exception acEx)
                        if (acEx.Message == "eUndefinedLineType")
                            PrintToCmdLine(string.Format(
                                    "\n ERROR: Could not load linetype \"{0}\", using CONTINUOUS instead.",
                                    linetypeName));
                            ltypeId = db.ContinuousLinetype;
                            return ltypeId;
                        else
                                "\n ERROR: in 'LibTools.GetOrLoadLinetypeId' loading linetype \"{0}\".",
                                linetypeName));
                            throw acEx;
            return ltypeId;
        public static ObjectId GetSymbolTableRecId(System.Type classType, string symName, Database db)
            ObjectId tblId = GetSymbolTableId(classType, db);
            ObjectId recId = new ObjectId();
                SymbolTable tbl = (SymbolTable)tr.GetObject(tblId, OpenMode.ForRead);
                if (tbl.Has(symName))   // TBD: should indexer return ObjectId.null instead of throwing exception
                    recId = tbl[symName];
                tr.Commit();
            return recId;
        public static ObjectId GetSymbolTableId(System.Type classType, Database db)
            Debug.Assert(classType != null);
            Debug.Assert(db != null);
            if (classType == typeof(BlockTableRecord))
                return db.BlockTableId;
            else if (classType == typeof(DimStyleTableRecord))
                return db.DimStyleTableId;
            else if (classType == typeof(LayerTableRecord))
                return db.LayerTableId;
            else if (classType == typeof(LinetypeTableRecord))
                return db.LinetypeTableId;
            else if (classType == typeof(TextStyleTableRecord))
                return db.TextStyleTableId;
            else if (classType == typeof(RegAppTableRecord))
                return db.RegAppTableId;
            else if (classType == typeof(UcsTableRecord))
                return db.UcsTableId;
            else if (classType == typeof(ViewTableRecord))
                return db.ViewTableId;
            else if (classType == typeof(ViewportTableRecord))
                return db.ViewportTableId;
            else
                Debug.Assert(false);
                ObjectId nullObj = new ObjectId();
                return nullObj;
        static public void createLayerXML(string Lname)
                if (lt == null)
                    return;
                if (lt.Has(Lname))
                    return;
                else
                    DataSet dsLayerData = new DataSet();
                    dsLayerData.ReadXml(@"c:\LayerDefinitions.xml");
                    DataView dsLayerDefinition = new DataView(dsLayerData.Tables["Layer"]);
                    dsLayerDefinition.Sort = "LayerName";
                    int rowIndex = dsLayerDefinition.Find(Lname);
                    if (rowIndex == -1)
                        ed.WriteMessage("Bogus Layer Name");
                    else
                        short lC = Convert.ToInt16(dsLayerDefinition[rowIndex]["Color"]);
                        string lnT = dsLayerDefinition[rowIndex]["LineType"].ToString();
                        LinetypeTable LTT = tr.GetObject(db.LinetypeTableId, OpenMode.ForRead, false) as LinetypeTable;
                        if (LTT == null)
                            return;
                        if (LTT.Has(lnT))
                            return;
                        else
                            LinetypeTableRecord newLTTR = new LinetypeTableRecord();
                            newLTTR.Name = lnT;
                            LTT.UpgradeOpen();
                            LTT.Add(newLTTR);
                            tr.AddNewlyCreatedDBObject(newLTTR, true);
                        //string layerColor = dsLayerDefinition[rowIndex]["Color"].ToString();
                        //short  lC = Convert.ToInt16(layerColor);
                        newLTR.Color = Color.FromColorIndex(ColorMethod.ByAci, lC);
                        //newLTR.LinetypeObjectId = newLTTR;
                        lt.UpgradeOpen();
                        lt.Add(newLTR);
                tr.Commit();
        public static void PrintToCmdLine(string str)
            ed.WriteMessage(str);
David Hall
« Reply #5 on: April 10, 2008, 03:53:34 PM »
/*#region System using declarations
using System;
using System.Collections;
using System.Text;
//using System.Drawing;
using System.Reflection;
//using System.Windows.Forms;
using System.ComponentModel;
using System.Text.RegularExpressions;
#endregion
#region AutoCAD COM Interop using declarations
//// COM Interop References
//// AutoCAD 2006 Type Library
//using Autodesk.AutoCAD.Interop;
//// AXDBLib AutoCAD/ObjectDBX Common 16.0 Type Library
//using Autodesk.AutoCAD.Interop.Common;
#endregion
#region AutoCAD Managed Wrappers using declarations
//// Assembly acdbmgd .. ObjectDBX.NET Managed Wrapper
//// Assembly acmgd .. Autocad.NET Managed Wrapper
#endregion
#region Alias using declarations
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
#endregion
[assembly: ExtensionApplication(typeof(ClassLibraryLab03.kwbLab03StartApp))]
[assembly: CommandClass(typeof(ClassLibraryLab03.Commands))]
namespace ClassLibraryLab03
    #region CommandClass
    public class
    Commands
        [CommandMethod("Lab03Help", CommandFlags.Modal)]
        static public void
        Lab03Help()
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("\n  Testing Assembly kwbLab03 [kwb v:20051204]");
            ed.WriteMessage("\n  Commands : LX1, LX2, LX3, LX4, LX5");
        [CommandMethod("LX1", CommandFlags.Modal)]
        public static void AssertLayerLX1()
            try
                ObjectId layerId = LibTools.CreateLayer("TestX1", 3, "HIDDEN");
                ed.WriteMessage("\n  layerId : " + layerId.ToString());
                ed.WriteMessage("\nError: " + acEx.Message);
                return;
        [CommandMethod("LX2", CommandFlags.Modal)]
        public static void AssertLayerLX2()
            try
                ObjectId layerId = LibTools.CreateLayer(" ", 113, "CONTINUOUS");
                return;
        [CommandMethod("LX3", CommandFlags.Modal)]
        public static void AssertLayerLX3()
            try
                ObjectId layerId = LibTools.CreateLayer("TestX3", 13, "NONE");
                return;
        [CommandMethod("LX4", CommandFlags.Modal)]
        public static void AssertLayerLX4()
            try
                ObjectId layerId = LibTools.CreateLayer("Test X4", 230, "DOT");
                return;
        [CommandMethod("LX5", CommandFlags.Modal)]
        public static void AssertLayerLX5()
            try
                ObjectId layerId = LibTools.CreateLayer("TestX5", 30000, "");
                return;
    #endregion
    #region MainApp core
    //public class Class1
    #endregion
    #region LibraryTools
    public class LibTools
        public static ObjectId CreateLayer(string layerName, short layerColor, string linetypeName)
            ObjectId layerId;
            Database  db = HostApplicationServices.WorkingDatabase;
                LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForWrite);
                if (lt.Has(layerName))
                        ltr.Erase(false);
                else // create the layer here.
                    if (layerColor > 255)
                        LibTools.PrintToCmdLine(string.Format(
                            "\n ERROR: Could not use LayerColor \"{0}\", using O instead.", layerColor));
                        layerColor = 0;
                    LayerTableRecord ltr = new LayerTableRecord();
                    ltr.Name = layerName;
                    ltr.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, layerColor);
                    ltr.LinetypeObjectId = GetOrLoadLinetypeId(linetypeName, db);
                    layerId = lt.Add(ltr);
                    tr.AddNewlyCreatedDBObject(ltr, true);
                tr.Commit();
            return layerId;
            if (ltypeId.IsNull)
                    LibTools.PrintToCmdLine(" \n Using Metric Linetypes");
                else
                    LibTools.PrintToCmdLine(" \n Using English Linetypes");
                    try
                            return ltypeId;
                                    linetypeName));
                            return ltypeId;
                        else
                                linetypeName));
                            throw acEx;
            return ltypeId;
        //---------------------------- awej MgdDbg rev.
                tr.Commit();
            return recId;
            else
                return nullObj;
        public static void
    #endregion
    #region Public class StartApp
    /// <summary>
    /// The entry point for AutoCAD.
    /// </summary>
    public class
    kwbLab03StartApp : IExtensionApplication
        public void
        Initialize()
            Commands.Lab03Help();
            ed.WriteMessage("\n  Type 'Lab03Help' at the Command Line for assistance ...");
        public void
        Terminate()
            // Does Nothing ... can't unload NET assembly ...
    #endregion
David Hall
« Reply #6 on: April 10, 2008, 03:55:17 PM »
David ,
Yes, well at least every time I try to crash it I can.  To reproduce problem, load a linetype (I used Hidden) and assign to a unused layer.  Then purge dwg.  Then call the function which loads the linetypes
Glenn R
« Reply #7 on: April 10, 2008, 04:00:00 PM »
Complex linetype?
Yep.
Duh,
This is the problem I ran into in 2005 and apparently it still exists...the default indexer problem.
Linkage
David Hall
« Reply #8 on: April 10, 2008, 04:01:16 PM »
I guess I forgot to mention that it appears to work UNTIL you open the Layer manager, at which point you get these screen shots.
David Hall
« Reply #9 on: April 10, 2008, 04:02:24 PM »
And Kerry, the above screen shots were created using your LX1  from the LibTools code you gave me
Glenn R
« Reply #10 on: April 10, 2008, 04:08:57 PM »
Here is TonyT's solution which is the best I've seen for this problem and is the one I use:
Linkage
David Hall
« Reply #11 on: April 10, 2008, 04:23:52 PM »
thanks Glenn, I need to read what he did and see how to use it
David Hall
« Reply #12 on: April 10, 2008, 04:44:25 PM »
Glenn, I must confess I don't quite understand how to use TT's code.
David Hall
« Reply #13 on: April 11, 2008, 05:49:08 PM »
Well I have tried all sorts of things today, and cant seem to figure out what I am missing.  Maybe I'll try to fix it this weekend
« Reply #14 on: April 11, 2008, 05:52:40 PM »
David,
'cause today is my playday I'll have a look too if I clear my todo list.
can you post or send the XML definition file, just for completeness.
Be well
