Author Topic: Linetype is purged  (Read 10223 times)
David Hall
  • Automatic Duh Generator
Re: Linetype is purged
« Reply #15 on: April 11, 2008, 05:58:05 PM »
Kerry, I was actually not using your XML file, is that the problem?  I was just passing the Linetype name I wanted manually thru code
Glenn R
« Reply #16 on: April 11, 2008, 05:58:44 PM »
can you post or send the XML definition file, just for completeness.
My eyes are hanging out of my head on stalks at the moment and I might have missed something, but...what XML file?
Duh,
What have you tried exactly? What stumped you about Tony's implementation?
Cheers,
Glenn.
David Hall
« Reply #17 on: April 11, 2008, 06:04:32 PM »
Glenn, Kerry's code has a part where he reads an XML file and creates layers based on the file.  I can post it if you need it.
The part that is stumping me is I am not sure what Im supposed to pass to his code to grab the "erased" id.  I'm also assuming you used the second piece(s) of code as that was being touted as faster/better.
« Reply #18 on: April 11, 2008, 06:05:27 PM »
Cheers,
Glenn.
        static public void createLayerXML(string Lname)
                    DataSet dsLayerData = new DataSet();
                    dsLayerData.ReadXml(@"c:\LayerDefinitions.xml");
                    DataView dsLayerDefinition = new DataView(dsLayerData.Tables["Layer"]);
                    dsLayerDefinition.Sort = "LayerName";
David Hall
« Reply #19 on: April 11, 2008, 06:16:24 PM »
I copied this into my code
//      // This is a much better/faster solution that P/Invokes
//      // AcDbSymbolTableRecord::getAt() directly from managed code:
        public static class AcDbSymbolTable
            // Acad::ErrorStatus AcDbSymbolTable::getAt(wchar_t const *, class AcDbObjectId &, bool)
            [System.Security.SuppressUnmanagedCodeSecurity]
            [DllImport("acdb17.dll", CallingConvention = CallingConvention.ThisCall, CharSet = CharSet.Unicode,
               EntryPoint = "?getAt@AcDbSymbolTable@@QBE?AW4ErrorStatus@Acad@@PB_WAAVAcDbObjectId@@_N@Z")]
            public static extern ErrorStatus getAt(IntPtr symbolTable, string name, out ObjectId id, bool getErased);
        public static ObjectId GetSymbolTableRecordId(SymbolTable table, string name)
            ObjectId id = ObjectId.Null;
            ErrorStatus es = AcDbSymbolTable.getAt(table.UnmanagedObject, name, out id, false);
            return id;
        public static ObjectId GetSymbolTableRecordId(ObjectId TableId, string name)
            using (Transaction tr = TableId.Database.TransactionManager.StartTransaction())
                SymbolTable table = (SymbolTable)tr.GetObject(TableId, OpenMode.ForRead);
                try
                    return GetSymbolTableRecordId(table, name);
                finally
                    tr.Commit();
and then was trying to figure out what to pass to which function to get the ID of the erased Linetype, and then trying to figure out how to unerase it.
Glenn R
« Reply #20 on: April 11, 2008, 06:17:03 PM »
Very quick and off the top of my head from looking at Tony's code again:
Database db = ...;
ObjectId someLinetypeTableRecordId = ObjectId.Null;
someLinetypeTableRecordId = DBUtils.GetSymbolTableRecordId(db.LinetypeTableRecord, "SomeLineTypeNameGoesHere");
if (someLinetypeTableRecordId != ObjectId.Null)
  // do some funky mojo here...
Glenn R
« Reply #21 on: April 11, 2008, 06:18:26 PM »
You REALLY don't want to UNERASE it. Read the discussion I posted earlier from the Adesk NG where Tony and I were discussing this particular problem.
« Reply #22 on: April 11, 2008, 06:21:20 PM »
FYI....
If you want to test if an ObjectId is Null, you can just use the property 'IsNull'.
David Hall
« Reply #23 on: April 14, 2008, 10:52:52 AM »
I must need more coffee, b/c I just re read the discussion b/t you and TT, and I just dont get it.  What I think I am supposed to do is check for the name and if its erased, create a new one.
« Reply #24 on: April 14, 2008, 11:19:04 AM »
That is how I do it in an insert block routine I just did, so I hope it is the right approach.  Mine works without crashing, so I figured it was a good solution.
David Hall
« Reply #25 on: April 14, 2008, 11:20:09 AM »
Thanks Tim.  I'll try and post what I got if I get to it today.
Glenn R
« Reply #26 on: April 14, 2008, 11:49:36 AM »
Essentially, yes.
David Hall
« Reply #27 on: April 14, 2008, 04:32:49 PM »
Thanks Glenn!  Only being able to look at this stuff every couple of weeks makes it very difficult to keep rational thoughts about what I was/am doing, and where I need to go.
David Hall
« Reply #28 on: May 27, 2008, 02:31:04 PM »
wow, looking at my last post, and then checking the date, its been a while.  Oh well, I have 2 days to work on this, and then I'm gone for a week.
David Hall
« Reply #29 on: May 27, 2008, 02:53:01 PM »
Well, I have some very good news!!!!!  It looks like they fixed the problem in 2009  :lol: :lol: :lol:  I loaded 09 last week, and just for grins decided to tell VS2008 to use 09.  Not remembering where I was with the whole problem, I began stepping thru the code to repeat the problem, and it ran flawlessly.  More testing to follow, but I think it is golden with regard to erased records
