Author Topic: Attributes in some block are not rotating properly thru the propertiest pallet  (Read 3808 times)
Krushert
  • FREE BEER Tomorrow!!
This is one of those annoyances that I am getting around to.
I have some attributes that when the block's rotation is changed in the properties pallet, the line work rotates as expected but the attribute does not.  It rotates about it inserted X,Y.  Thus I end up with as shown in the image.  Some blocks are doing and some are not.
I believe it is a setting with the attribute but which one?  I tried Lock Position but that did not have affect.
Evidently in 2008 there are many issues regarding rotating attributes and the rotation of blocks. See this post for what I found out about attribute rotation issues and programming interfaces.
Krushert
Interesting.
And yes, I insert 90% of my general annotation blocks via lisp. LIke I said some do it some don't.
I will rotate each instance the old fashion way; I guess.
Do you have a block that ALWAYS exhibits this behaviour ?
Can you post it. ?
Do you have a block that NEVER exhibits this behaviour ?
Can you post it. ?
Krushert
Here is the one in the screen shot.  This one "seems" to always exhibit the issue.
When I come up for air I will try to find that is not doing it.
Crank
I have no problems with the block (Acad2008 vanilla-SP1 and all hotfixes).
But you can try to set the lock position of the attribute (BEDIT > select attrib > PROPERTIES > MISC > LOCK POSITION > YES)
Krushert
I tried the lock position and got nothing.  I will try it again and I will see if I have all the hotfixes.  I have the SP1 though.
Thanks.
Crank
Sorry but I didn't rotate with the properties. This is a normal behaviour.
Attributes aren't part of the block, but referenced to the block. It's possible to have several inserts of the same block, each with different attributes.
If you change the properties the attribute rotates around it's own textinsertion point. Because both insertion points aren't the same the block and the attribute are rotating different. To get the attributes on the default location you can use the ATTSYNC command.
Another solution would be to make the insertionpoint the same as the attribute. You can add another insertionpoint on the current position. (see attached example)
The behavior you note is not the behavior on any version of AutoCAD until 2008. Autodesk makes no mention of this change in behavior and thus that is why I (we) classify it as a bug.
It worked .. then it didn't
Incidently, if the behavior you mention is the way it "should" behave, then the regular rotate command should leave the attributes alone as well .. which it does not.
Krushert
Whoa,  Interesting.
Krushert
I like this option.  Thanks for the workaround.  This step is a little more efficient than rotating each instance.
Crank
@Keith: I'll have to check on this. If you're right I'll report it.
@Krushert: If you make a dynamic block you can add a rotate action to this block so that it rotates everything. Then it's possible to use properties.
elsos
Thanks, guys, ATTSYNC will work for now.  We have been going crazy with this issue!!  Still a real pain for us as we use the Properties box alot with scaling and rotating some of our blocks with attributes.
I'll be looking in to see if there is anything new to make it like it was before 2008.
-Eric
Keep in mind this problem is also present in 2009 so I would doubt it has been fixed.
elsos
Arrg.
So is there some setting in an obscure place that might be changed or 'reset' to make all blocks with attributes act as they should?
I'm dreaming again, huh?
