Author Topic: Attributes in some block are not rotating properly thru the propertiest pallet  (Read 3837 times)
unfortunately .. this affects the tool pallete as well as lisp and vba programming. I suspect it has to do with the introduction of associative annotation, but I can't prove it.
Krushert
  • FREE BEER Tomorrow!!
Well and low behold Autocad has address this bug thru a driver update/hotfix
Rotating Attributes Hotfix
This hotfix repairs a problem with the rotation of attributes inside blocks.
Description of Problem
When you set rotation using the Properties palette, blocks attributes fail to rotate properly.
They only mention of fixing the rotation issue when using the properties pallet.  If it fixes the other methods that was mention above, I don't know.
dustinthiesse
I just discovered this hotfix, and it does fix the rotation problems.
However, it doesn't fix the scaling problem.  Does anyone know if there is a fix out there for scaling as well?
