Author Topic: Sliding Doors  (Read 8230 times)
42
Sliding Doors
« on: January 08, 2008, 04:00:10 PM »
I am using ADT 2008
As a standard ADT has a pocket door showing the door sliding into the wall, what I want is for the door to slide along the face of the wall, well 50mm (2") away from it. Any leads on modifying the display?
Alastair
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
Dommy2Hotty
Re: Sliding Doors
« Reply #1 on: January 08, 2008, 05:32:22 PM »
Use a custom block for the door and modify it's position to be away from the wall...
Greg B
  • Tell me a Joke!
Re: Sliding Doors
« Reply #2 on: January 08, 2008, 05:45:02 PM »
ADT doesn't have a track door?
42
Re: Sliding Doors
« Reply #3 on: January 08, 2008, 05:47:28 PM »
Thanks D2H. I have just managed to work this out myself!. Now I should remember.
« Last Edit: January 08, 2008, 05:52:06 PM by 42 »
Technical Director
Steve(UK)
Re: Sliding Doors
« Reply #4 on: January 09, 2008, 08:28:45 AM »
It has single and double pocket doors (mentioned above) which slides into the wall/jambs, or double and triple sliding doors which slide within the opening.
Adding custom blocks is fine but won't allow you to change the opening percentage (not that you would need to with that type of door I guess).
Re: Sliding Doors
« Reply #5 on: January 09, 2008, 09:34:06 AM »
Or, it is time to draw the sliding doors' geometry, and then create a New door type from that linework.
Steve(UK)
Re: Sliding Doors
« Reply #6 on: January 10, 2008, 06:36:19 AM »
How do you mean, a door style always has to use one of the predefined door types under the design rules (single, double, uneven, bi-fold, etc), you can create new geometry to form a profile to change the elevational shape of a door. Are you saying you can create new door types from linework to add to the list in the design rules?
Re: Sliding Doors
« Reply #7 on: January 10, 2008, 09:53:39 AM »
Yes, that is exactly what I am saying, YOU can add door and window and wall styles to YOUR content library to reuse. Here are a couple links that hint at how it works.  Your current version of help will be a good guide as well.
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5543204&linkID=9240657
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5911339&linkID=9240657
Beware, unless it has been fixed, once you do this, it automatically places the geometry perpendicular to the plan view, you most likely just drew it in, and it appears to make the lines vanish.
