As usual I'm a bit late to the party.
![sad :-(](http://www.theswamp.org/Smileys/black/sad.gif)
Anyway, here's my offering which allows the beginning station to be any number, which happens often for me when tying to existing designs. I also use the existing STA block, if it exists in the drawing but does not have an attribute for the Station then I add it to the block def.
(defun c:station (/ ANG ATT ATTS BLK BLKREF DERV DOC ENT LINE PAD PARM SPACE STA TMPSTA)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(if (not (tblsearch "block" "sta"))
(setq blk (vlax-invoke (vla-get-blocks doc) 'add '(0.0 0.0 0.0) "sta"))
(setq line (vlax-invoke blk 'addline '(0.0 31.25 0.0) '(0.0 -31.25 0.0)))
(vla-put-layer line "0")
(vla-put-color line acbylayer)
(setq att (vlax-invoke blk 'addattribute
15.0
acAttributeModeNormal
"Station number?: "
'(0.0 35.0 0.0)
"STATION"
"0+00"))
(vla-put-layer att "0")
(vla-put-color att acbylayer)
(if (and (setq blk (vla-item (vla-get-blocks doc) "sta"))
(= (vla-get-count blk) 1)
15.0
"Station number?: "
'(0.0 35.0 0.0)
"STATION"
"0+00"))
(vla-put-rotation att (* pi 1.5))
(vla-put-alignment att acAlignmentMiddleRight)
(vlax-put att 'TextAlignmentPoint '(0.0 35.0 0.0))
(while (and (setq ent (car (entsel)))
(setq sta (getreal "Starting station: "))
(setq tmpsta (fix (/ sta 100))
pad (- sta (* tmpsta 100.0))
space (vla-get-modelspace doc)
(if (/= pad 0.0)
(setq tmpsta (1+ tmpsta))
(while (<= (* tmpsta 100) (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)))
(setq parm (vlax-curve-getparamatdist ent (- (* tmpsta 100.0) pad)))
(setq derv (vlax-curve-getfirstderiv ent parm))
(if (= (car derv) 0.0)
(setq ang (/ pi 2))
(setq ang (atan (/ (cadr derv) (car derv))))
(setq blkref (vlax-invoke space 'insertblock (vlax-curve-getpointatparam ent parm) "sta" 1.0 1.0 1.0 ang))
(setq atts (vlax-invoke blkref 'getattributes))
(setq att (car atts))
(vla-put-textstring att (strcat (itoa tmpsta) "+00"))
