Author Topic: Stationing Lisp  (Read 11439 times)
Scott
Stationing Lisp
« on: November 24, 2007, 12:58:39 AM »
Hello all,
I'm looking for an easy way to put stationing on centerlines of berm and for pipelines.  I know I can use the Measure command to mark the stations, but I have to manually put in the station id ie 0+00, 1+00 etc.  Does anyone know of a way to automate the station id input.  I'm using Map 5.  Any help is greatly appreciated.
Scott
wizman
Re: Stationing Lisp
« Reply #1 on: November 24, 2007, 05:10:53 AM »
Hello all,
Scott
http://forums.augi.com/showthread.php?t=69720&highlight=FIXO
Scott
Re: Stationing Lisp
« Reply #2 on: November 24, 2007, 01:10:20 PM »
Wizman
Thanks for the link, but it won't work.  Probably user error.  It says there is no text/mtext with similar properties selected.  Anyway, I've been playing with the measure command.  Does anyone know if there is a way to scale a block before it is inserted with the measure command?  I also need to be able to automate the station id.  I'm to lazy to explode all the blocks and change each one individually.
Thanks again
Scott
Fatty
Re: Stationing Lisp
« Reply #3 on: November 24, 2007, 02:06:25 PM »
Here is my 10-minutes solution
Not sure about that what you exactly need
Let me know if you want to change something here
(defun C:STN  (/ hgt init pt)
  (princ "\n Stationing pipelines ")
  (setq hgt (getreal "\n Enter text height: "))
  (setq init (getint "\n  Enter initial number <0>: "))
  (if (not init)
    (setq init 0)
  (command "._undo" "e")
  (command "._undo" "g")
  (while (setq pt (getpoint "\n  Pick point to label (hit Enter to stop):"))
    (entmake
      (list
(cons 0 "TEXT")
(cons 100 "AcDbEntity")
(cons 100 "AcDbText")
(cons 1 (strcat (itoa init) "+00"))
(cons 10 pt)
(cons 40 hgt)
(cons 50 0.0)
(cons 51 0.0)
(cons 11 pt)
(cons 71 0)
(cons 72 1)
(cons 73 1)
    (setq init (1+ init))
  (command ".undo" "e")
(princ "\ Start command with STN to run")
~'J'~
Scott
Re: Stationing Lisp
« Reply #4 on: November 24, 2007, 03:00:34 PM »
Fatty
I can make this work if it is possible to have the text aline parellel with a line running perpendicular to my pipeline.  Is this possible?
Scott
Re: Stationing Lisp
« Reply #5 on: November 24, 2007, 03:07:58 PM »
This is what I am looking for.
Again Thanks for the help!!
kpblc
Re: Stationing Lisp
« Reply #6 on: November 24, 2007, 04:59:00 PM »
try (i didn't test it)
(defun c:stn (/ hgt init pt)
  (if (and (member (type (setq hgt
                                (vl-catch-all-apply
                                  '(lambda (/ text_height)
                                     (setq text_height
                                              ((= 0.
                                                  (cdr (assoc
                                                         40
                                                         (entget
                                                           (tblobjname
                                                             "style"
                                                             (getvar "textstyle")
                                                             ) ;_ end of tblobjname
                                                           ) ;_ end of entget
                                                         ) ;_ end of assoc
                                                       ) ;_ end of cdr
                                                  ) ;_ end of =
                                               3.5
                                              (t
                                               (cdr
                                                 (assoc
                                                   40
                                                   (entget
                                                     (tblobjname "style" (getvar "textstyle"))
                                                     ) ;_ end of entget
                                                   ) ;_ end of assoc
                                                 ) ;_ end of cdr
                                              ) ;_ end of cond
                                           ) ;_ end of setq
                                       ((getreal (strcat "\n Enter text height <"
                                                         (rtos text_height 2)
                                                         ) ;_ end of strcat
                                                 ) ;_ end of getreal
                                       (t text_height)
                                       ) ;_ end of cond
                                     ) ;_ end of lambda
                                  ) ;_ end of vl-catch-all-apply
                               ) ;_ end of setq
                         ) ;_ end of type
                   (list 'int 'real)
                   ) ;_ end of member
           (= (type (setq init (vl-catch-all-apply
                                 '(lambda ()
                                      ((getint "\n  Enter initial number <0>: "))
                                      (t 0)
                                      ) ;_ end of cond
                                    ) ;_ end of lambda
                          ) ;_ end of setq
                    ) ;_ end of type
              'int
              ) ;_ end of =
           ) ;_ end of and
      (vla-endundomark
        (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
        ) ;_ end of vla-endundomark
      (vla-startundomark adoc)
      (while
        (= (type (setq
                   ent (vl-catch-all-apply
                         '(lambda ()
                            (entsel "\nSelect an entity <Cancel> : ")
                            ) ;_ end of lambda
                   ) ;_ end of setq
                 ) ;_ end of type
           'list
           ) ;_ end of =
         (setq pline (vlax-ename->vla-object (car ent))
               pt    (vlax-curve-getclosestpointto pline (cadr ent))
               ) ;_ end of setq
         (entmakex (list
                     (cons 0 "TEXT")
                     (cons 10 pt)
                     (cons 40 2.5)
                     (cons 50
                           (- (angle '(0. 0. 0.)
                                     (vlax-curve-getfirstderiv
                                       pline
                                       (vlax-curve-getparamatpoint pline pt)
                                       ) ;_ end of vlax-curve-getSecondDeriv
                                     ) ;_ end of angle
                              (/ pi 2.)
                              ) ;_ end of -
                           ) ;_ end of cons
                     ) ;_ end of list
                   ) ;_ end of entmakex
         ) ;_ end of while
      (vla-endundomark adoc)
      ) ;_ end of progn
    ) ;_ end of if
  ) ;_ end of defun
Sorry for my English.
Scott
Re: Stationing Lisp
« Reply #7 on: November 24, 2007, 07:04:13 PM »
I get the following when I run the lisp.
 stn
 Enter text height <3.5000>:
Select an entity <Cancel> : ; error: bad argument value: AcDbCurve 1074538688
Command:
Scott
Re: Stationing Lisp
« Reply #8 on: November 24, 2007, 07:21:09 PM »
kpblc
Okay I figured out why is wasn't working.  When I use measrue to insert my cross line, it comes in as a block.  The block has to be exploded before your routine will work.  No the only problem with the routine is the station ID comes in rotated 90 degrees from what it should be.  Idealy, I would have a routine that would invoke the measure command or some other method of inserting the station marks and automatically insert the station id as well.  I'm guessing this would take some time to write the code, and I don't want to impose on anyone.  So for now, if I can get the measure command and your routine to work I will use them.  Anyway to incorporate this routine in with yours?
http://www.theswamp.org/index.php?topic=15117.0
Scott
« Last Edit: November 24, 2007, 08:08:49 PM by Scott »
Re: Stationing Lisp
« Reply #9 on: November 25, 2007, 07:29:55 AM »
Scott,
If you would post a sample DWG with the stationing blocks along a centerline and one for pipelines
it would help.
Re: Stationing Lisp
« Reply #10 on: November 25, 2007, 07:37:50 AM »
As for the angle, change this
         (entmakex (list
                     (cons 0 "TEXT")
                     (cons 10 pt)
                     (cons 40 2.5)
                     (cons 50
                                       pline
                              ) ;_ end of angle
                              (/ pi 2.)
                           ) ;_ end of -
                     ) ;_ end of cons
                   ) ;_ end of list
to this
         (setq curDer (vlax-curve-getfirstderiv cCurve
                        (vlax-curve-getparamatpoint cCurve Pt)))
         ;; Get angle 90 deg to curve
         (if (= (cadr curDer) 0.0)
           (setq curAng (/ pi 2))
           (setq curAng (- pi (atan (/ (car curDer) (cadr curDer)))))
         (entmakex (list
                     (cons 0 "TEXT")
                     (cons 10 pt)
                     (cons 40 2.5)
                     (cons 50 curAng)
                   ) ;_ end of list
kpblc
Re: Stationing Lisp
« Reply #11 on: November 25, 2007, 03:13:26 PM »
Another version (CAB, your code more professional):
(defun c:stn2 (/            adoc         blk_def      blk_name     ent
               ent_blk      txt_height   ini_num      len          att
               sys_lst      lastent      lst_ent      loc:set-angle
               loc:conv-to-vla           loc:set-attr loc:get-attr res_height
  (defun loc:conv-to-vla (ent)
      ((= (type ent) 'vla-object) ent)
      (t (vlax-ename->vla-object ent))
      ) ;_ end of cond
    ) ;_ end of defun
  (defun loc:set-angle (ent / ang)
    (setq
      ang (+ (* pi 0.5) (vla-get-rotation (setq ent (loc:conv-to-vla ent))))
      ) ;_ end of setq
    (vla-put-rotation
        ((<= ang pi) (+ ang pi))
        ((<= ang (* pi 1.5)) (- ang pi))
        (t ang)
        ) ;_ end of cond
      ) ;_ end of vla-put-Rotation
    ) ;_ end of defun
  (defun loc:get-attr (ent)
    (car (vlax-safearray->list
           (vlax-variant-value (vla-getattributes (loc:conv-to-vla ent)))
           ) ;_ end of vlax-safearray->list
         ) ;_ end of car
    ) ;_ end of defun
  (defun loc:set-attr (ent ini)
    (vla-put-textstring
           ) ;_ end of car
      (strcat (itoa ini) "+00")
      ) ;_ end of vla-put-textstring
    ) ;_ end of defun
  (defun *error* (msg)
    (if sys_lst
      (mapcar '(lambda (x) (setvar (car x) (cdr x))) sys_lst)
      ) ;_ end of if
    (princ msg)
    ) ;_ end of defun
  (vla-startundomark
    ) ;_ end of vla-startundomark
  (setq sys_lst (mapcar '(lambda (x) (cons x (getvar x)))
                        '("osmode" "cmdecho" "nomutt")
                        ) ;_ end of mapcar
        ) ;_ end of setq
    (and
      (member
        (type
          (setq txt_height
                 (vl-catch-all-apply
                   '(lambda (/ h)
                      (if (= 0.
                             (setq h (vla-get-height
                                       (vla-get-activetextstyle adoc)
                                       ) ;_ end of vla-get-Height
                                   ) ;_ end of setq
                             ) ;_ end of =
                        (setq h 2.5)
                        ) ;_ end of if
                        ((getdist (strcat "\nEnter text height <"
                                          (vl-princ-to-string h)
                                          ) ;_ end of strcat
                                  ) ;_ end of getdist
                        (t h)
                        ) ;_ end of cond
                      ) ;_ end of lambda
                ) ;_ end of setq
          ) ;_ end of type
        (list 'real 'int)
        ) ;_ end of member
      (= (type (setq ini_num (vl-catch-all-apply
                               '(lambda ()
                                    ((getint "\nInitial number <0> : "))
                                    (t 0)
                                    ) ;_ end of cond
                                  ) ;_ end of lambda
                     ) ;_ end of setq
               ) ;_ end of type
         'int
         ) ;_ end of =
      (member (type (setq len (vl-catch-all-apply
                                '(lambda ()
                                     ((getdist "\nLength of segment <1> : "))
                                     (t 1.)
                                     ) ;_ end of cond
                                   ) ;_ end of lambda
                          ) ;_ end of setq
                    ) ;_ end of type
              (list 'int 'real)
              ) ;_ end of member
      (= (type (setq
                       '(lambda ()
                          (car (entsel "\nSelect a [poly]line <Cancel> : "))
                          ) ;_ end of lambda
                 ) ;_ end of setq
               ) ;_ end of type
         'ename
         ) ;_ end of =
      ) ;_ end of and
       (setq lastent (entlast)
             ini_num (1- ini_num)
             ) ;_ end of setq
       (if (not (tblobjname "block" (setq blk_name "scott_mark")))
           (setq blk_def (vla-add (vla-get-blocks adoc)
                                  (vlax-3d-point '(0. 0. 0.))
                                  blk_name
                                  ) ;_ end of vla-add
                 ) ;_ end of setq
           (vla-addline
             blk_def
             (vlax-3d-point '(-2.5 0. 0.))
             (vlax-3d-point '(2.5 0. 0.))
             ) ;_ end of vla-addline
           (setq att (vla-addattribute
                       blk_def
                       txt_height
                       acattributemodenormal
                       "mark"
                       (vlax-3d-point '(3. 0. 0.))
                       "mark"
                       ) ;_ end of vla-AddAttribute
                 ) ;_ end of setq
           (vla-put-alignment att acalignmentmiddleleft)
           (vla-put-insertionpoint att (vlax-3d-point '(3.0 0. 0.)))
           (vla-put-textalignmentpoint att (vlax-3d-point '(3.0 0. 0.)))
           (vlax-for subent blk_def
             (vla-put-layer subent "0")
             (vla-put-color subent 0)
             (vla-put-lineweight subent aclnwtbyblock)
             (vla-put-linetype subent "byblock")
             ) ;_ end of vlax-for
           ) ;_ end of progn
         ) ;_ end of if
               '(("osmode" . 0) ("cmdecho" . 0) ("nomutt" . 1))
               ) ;_ end of mapcar
       (vl-cmdf "_.measure" ent "_b" blk_name "_y" len)
       (while (setq lastent (entnext lastent))
         (if (not (vlax-erased-p (vlax-ename->vla-object lastent)))
           (setq lst_ent (cons (loc:conv-to-vla lastent) lst_ent))
           ) ;_ end of if
         ) ;_ end of while
       (vl-cmdf "_.attsync" "_n" blk_name)
       (foreach item lst_ent
         (if (/= (setq res_height (vla-get-height (loc:get-attr item)))
                 txt_height
                 ) ;_ end of /=
           (vla-scaleentity
             item
             (vla-get-insertionpoint item)
             (/ txt_height res_height)
             ) ;_ end of vla-scaleentity
           ) ;_ end of if
         (vla-update item)
         (loc:set-angle item)
         (loc:set-attr item (setq ini_num (1+ ini_num)))
         ) ;_ end of foreach
       ) ;_ end of progn
     ) ;_ end of if
  (if sys_lst
    ) ;_ end of if
  ) ;_ end of defun
I modified code to set new text height
« Last Edit: November 25, 2007, 03:25:46 PM by kpblc »
Scott
Re: Stationing Lisp
« Reply #12 on: November 25, 2007, 03:34:18 PM »
Cab
Attached is the drawing of what I'm looking for and my current procedure for obtaining the results.
kpblc
I tried your routine, and I must be doing something wrong.  It inserts the station mark fine, but I can't figure out how to the the station ID to come in.
Thanks for the help
Scott
Re: Stationing Lisp
« Reply #13 on: November 25, 2007, 03:43:45 PM »
kpblc
I'm getting an "error collecting attribute data" message when I run your lisp.
Any Ideas?
Scott
Fatty
Re: Stationing Lisp
« Reply #14 on: November 25, 2007, 04:51:49 PM »
Try this instead
(defun C:DP  (/ ang ccw coors d step dif dis en
      hgt init ip len n obj sign st txp)
;; ========= convert radians to degrees=====================;;
(defun rtd (a)
  (* 180.0 (/ a pi))
(defun dif-angle (ang1 ang2 / step)
  (set 'ang1
       (if (> ang2 (+ pi ang1))
(+ (* pi 2) ang1)
ang1
  (set 'ang2
       (if (> ang1 (+ pi ang2))
(+ (* pi 2) ang2)
ang2
  (setq step (- ang2 ang1))
(defun ccw-test (pt_list / angle_list)
  (setq angle_list
(mapcar (function (lambda (x y)
     (angle x y)
pt_list
(cdr pt_list)
  (if (> (apply '+
(mapcar (function (lambda (x y) (dif-angle x y)))
angle_list
(cdr angle_list)
0
    t
    nil
;;;written by Luis Esquivel
(defun get-coors (obj / cnt lst)
(setq cnt (fix (vlax-curve-getendparam obj)))
(while (> cnt 0)
  (setq lst (cons (vlax-curve-getpointatparam obj cnt) lst)
cnt (1- cnt)))
       lst
;;========= get perpendicular angle to curve ===============;;
;; written by CAB
(defun perp_angle (obj pt / fder)
(setq fder (vlax-curve-getfirstderiv obj
                        (vlax-curve-getparamatpoint obj
  (vlax-curve-getclosestpointto obj pt))))
(if (equal (cadr fder) 0.0 0.001)
           (setq ang (/ pi 2))
           (setq ang (- pi (atan (/ (car fder) (cadr fder)))))
  ang
;;=================== entmake text=========================;;
  (defun emake-text (pt ang hgt i /)
    (entmake
      (list
(cons 0 "TEXT")
(cons 10 pt)
(cons 40 hgt)
(cons 50 ang)
(cons 51 0.0)
(cons 11 pt)
;;=====================  < main part >  ==================;;
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (setq obj (vlax-ename->vla-object (car (setq en (entsel)))))
    (setq hgt (getreal "\n Enter text height <15>: "))
    (if (not hgt)
    (setq hgt 15)
  (if (not init)
    (setq init 0)
  (setq st (cadr en))
  (setq len
         (vlax-curve-getdistatparam obj
  (setq coors (get-coors obj)
ccw (ccw-test coors)
  (if (not step)
      (setq step 100)
  (setq d (getdist (strcat "\nStep of stations in cm <" (rtos step) ">: ")))
  (if (not d) (setq d step) (setq step d)
  (if (< (vlax-curve-getdistatpoint obj
   (vlax-curve-getclosestpointto obj st))
       (- (vlax-curve-getdistatpoint obj
   (vlax-curve-getendpoint obj))
   (vlax-curve-getclosestpointto obj st)))
    (setq sign 1
  dis 0)
    (setq sign -1
  dis len)
  (setq n (fix (/ len d))
dif (- len (* n d))
  (repeat (1+ n)
  (setq ip (vlax-curve-getpointatdist obj dis)
      ang (perp_angle obj ip)
 (command "._-insert" "STA" ip  1 1 (rtd (if ccw (+ ang (/ pi 2))(- ang (/ pi 2)))))
 (setq txp (polar ip (if ccw ang (+ pi ang)) (* hgt 3)));<-- text gap from pipeline
 (emake-text txp (if ccw ang (+ pi ang)) hgt init)
(setq dis (+ dis (* sign d)))
  (setvar "cmdecho" 1)
  (setvar "osmode" 175)
(princ "\nType DP to stationing ")
~'J'~
