Author Topic: Clip Boundaries for a Raster  (Read 39594 times)
ML
Re: Clip Boundaries for a Raster
« Reply #75 on: November 15, 2007, 07:10:13 PM »
Actually
I opened ACAD  LOL
I think (not sure) it has something to do with the getreal method but I am not sure.
I tried Declaring the variable as Integer then I realized that is only good if where want a whole number.
Then I tried as Variant and it works sometimes but not others.
So, I'm sure we will get it
Bob Wahr
« Reply #76 on: November 15, 2007, 07:21:54 PM »
The opening acad wasn't a knock on you.  I'm working in Revit at the moment so I've just been guessing.  I'm 98% sure that getreal returns a double.
David Hall
  • Automatic Duh Generator
« Reply #77 on: November 16, 2007, 09:31:12 AM »
yes
David Hall
« Reply #78 on: November 16, 2007, 09:33:31 AM »
GetInteger gets an Integer whilst GetReal gets a Double
David Hall
« Reply #79 on: November 16, 2007, 09:36:17 AM »
I think it might be here
  Dim Bndsize As Integer
  Bndsize = ThisDrawing.Utility.GetReal("What size boundary would you like?: ")
You are declaring an Integer, but asking for a Double
I would change it to Dim BndSize as Double
« Last Edit: November 16, 2007, 09:37:35 AM by CmdrDuh »
ML
« Reply #80 on: November 16, 2007, 11:12:56 AM »
Hey Bob
It wasn't taken as such  :-)
I thought you were on your way home but still curious.
I know I have closed down, went to the men's room, got all my stuff together and said, hummmm, let me turn CAD on real quick; then 2 hours went by. So, once I shutdown; I really do try to "shutdown"  :-)
Revit huh? That sounds really cool! So you do 3D Modeling then?
CM, thank you for that little tip, I will use getreal and try using Double as my data type.
Do you think that is what is causing this method
  clipPoints(0) = mdpnt(0) - (Bndsize / 2): clipPoints(1) = mdpnt(1) - (Bndsize / 2)
  clipPoints(2) = mdpnt(0) - (Bndsize / 2): clipPoints(3) = mdpnt(1) + (Bndsize / 2)
  clipPoints(4) = mdpnt(0) + (Bndsize / 2): clipPoints(5) = mdpnt(1) + (Bndsize / 2)
  clipPoints(6) = mdpnt(0) + (Bndsize / 2): clipPoints(7) = mdpnt(1) - (Bndsize / 2)
  clipPoints(8) = mdpnt(0) - (Bndsize / 2): clipPoints(9) = mdpnt(1) + -(Bndsize / 2)
To work sometimes and not others?
Have you tried this method yet?
ML
« Reply #81 on: November 16, 2007, 11:20:50 AM »
Yes sir (CM) my friend,
You nailed it! It seems to be wroking perfect now
We want Bndsize as Double
Dim Bndsize As Double
Bob, that method was a really cool idea!
David Hall
« Reply #82 on: November 16, 2007, 11:25:48 AM »
Yes, but you know that b/c you just posted faster than me.  By having it as integer you had a 50% chance it would round off to the correct number, and 50% it didn't.  By using Double, you are getting the correct number and processing it from there
ML
« Reply #83 on: November 16, 2007, 11:31:23 AM »
Yep
Very cool indeed!
So, you guys rastered out or what?
Bob Wahr
« Reply #84 on: November 16, 2007, 11:36:53 AM »
trying to get more work done today.  Where are you at now in terms of things working/not working?
ML
« Reply #85 on: November 16, 2007, 01:58:22 PM »
Bob! You mean you don't work for us? LOL  J/K
Everything as far as I can see is working A OK.
Very nice indeed.
I am really impressed by the dynamic boundary creations.
This discussion has really helped me learn more about getting, using and manipulating points.
And creating boundaries of course.
Now, I am thinking about putting the raster into a selection set in case I need to do something with after the user exits the sub or whatever.
After that, I think I will leave good enough alone.
ML
« Reply #86 on: November 16, 2007, 03:56:53 PM »
Hey guys,
Let me throw this out there.
I noticed if I pick 2 points on the raster and the slection is less then 5' x 5' then only an image frame will display.
I know, "NO S**T, right?
Well, I am not sure that the user would understand why this is happening; so I am wondering if we can do something that will say, if picked boundary is less then 5' x 5' or in Bob's other code where the user types in the boundary size, can we catch that error?
I don't think we can say:
Select Case ClipPoints
 etc. etc.
End Select
However I could be wrong
THanks
ML
« Reply #87 on: November 19, 2007, 01:13:35 PM »
I am going to attempt to answer my own question here:
"After" or "when" the raster is inserted; I believe we can get the height and width of the raster.
After we have that, we can write some code that will say: If the boundary is > then the height and width of the inserted raster, then
Handle Error
ML
« Reply #88 on: November 19, 2007, 01:16:00 PM »
ACtually, I noticed an error is not returned, you are just left with an imageframe with none of the image showing, so we would probably need to return a message to the user:
Msgbox " The specified boundary is too large etc. etc."
David Hall
« Reply #89 on: November 19, 2007, 01:42:08 PM »
I would say post the image you are working with so we can all play along
