Author Topic: Clip Boundaries for a Raster  (Read 42888 times)
ML
Re: Clip Boundaries for a Raster
« Reply #180 on: November 28, 2007, 05:45:37 PM »
Absolutely and I respect your suggestions and appreciate all your help :)
I was actually pretty much done with the whole project then I ran into a situation today where no rasters exisited so I addressed that, then I thought, what if there is more then one in the drawing?
As you know, we can not account for every little thing.
At this point, I think I will leave good enough alone.
Thanks again,
Bob Wahr
« Reply #181 on: November 28, 2007, 05:50:46 PM »
cool dat.
ML
« Reply #182 on: November 28, 2007, 05:55:29 PM »
ML
« Reply #183 on: December 04, 2007, 04:25:54 PM »
Hey guys
Another question:
We already have our midpoint
Dim mdpnt(0 To 2) As Double
mdpnt(0) = (llpnt(0) + urpnt(0)) / 2 'Midpoint (X)
mdpnt(1) = (llpnt(1) + urpnt(1)) / 2 'Midpoint (Y)
mdpnt(2) = 0
And the code to move the raster
'Move Points
 Dim MPointN(0 To 2) As Double 'Negative
 Dim MPointP(0 To 2) As Double 'Positive
 MPointN(0) = 0: MPointN(1) = 0: MPointN(2) = 0
 MPointP(0) = 0: MPointP(1) = 0: MPointP(2) = 0
'Move Raster
RastImg.Move MPointN, MPointP
Now, what if we want to move the raster from the midpoint that we already have to another midpoint else where, let's say in the middle of a 5'x5' square.
How would we do this:
I realize, we can have midpnt1 and a midpnt2
The question is more, how do we do the actual move with the raster.
Note: Also, this is after it has been clipped
Thanks,
ML
« Reply #184 on: December 04, 2007, 04:30:55 PM »
It looks like we somehow need a way to say move FROM midpnt1
Dim mdpnt1 (0 To 2) As Double
mdpnt1(0) = (llpnt(0) + urpnt(0)) / 2 'Midpoint (X)
mdpnt1(1) = (llpnt(1) + urpnt(1)) / 2 'Midpoint (Y)
mdpnt1(2) = 0
To Midpnt2 (0 to 2) as Double  'To be determined
Mdpnt2 (0)=
Mdpnt2 (1)=
Mdpnt2 (2)=
So, how does that translate into here?
'Move Raster
RastImg.Move Midpnt1 (this is from), Midpnt2 (this is to)
ML
« Reply #185 on: December 05, 2007, 11:19:33 AM »
When you look go to the end of the .move method, it prompts you for a From Point, To Point
In the scenario we originally used, we are giving it the negative and positive coords to move to.
In the above question, I am looking to truly go from a From Point (mdpnt), to a To Point (mdpnt1)
Just not quite sure how to get it; I have tried a few things but no luck?
Anyone?
David Hall
  • Automatic Duh Generator
« Reply #186 on: December 05, 2007, 02:36:59 PM »
What have you tried?
ML
« Reply #187 on: December 05, 2007, 03:46:34 PM »
Hey CM,
Good to see you back!
So far, I am just grasping for straws, time permitting.
I have tried something like this:
'Test Move Points
 Dim mdpnt1N(0 To 2) As Double
 Dim mdpnt1P(0 To 2) As Double
 mdpnt1N(0) = 0: mdpnt1N(1) = 0: mdpnt1N(2) = 0
 mdpnt1P(0) = 2.5: mdpnt1P(1) = 2.5: mdpnt1P(2) = 0
'Test Move Raster
 RastImg.Move mdpnt, mdpnt1N, mdpnt1P
So, I was trying to use our existing mdpnt which we know is constant each time we define our points to a mid point of a rectangle on a title block; that is where the clipped raster will end up.
So, that would be cool; after the user chooses their points, it will magically get moved to the necessary location for them, assuming I can get it to work.
I think after the move method, we can only use 2 variables and I am using 3 above which did not work for me.
The other thing is that the mdpnt will never be the same, so how do we address that?
We could say mdpnt = RastImg.Origin then perform the move; assuming that will first shift the clipped image to the original raster origin before performing the move.
What do you think?
ML
« Reply #188 on: January 14, 2008, 10:52:57 AM »
For those who are interested:
Here is how I finally moved the clipped raster to where I needed it to be on the drawing:
'***Move the raster***
 'Use the midpoint of the raster as the base point
  Dim Pnt As Variant
  Pnt = mdpnt
 '0,0
  Dim ZeroZero(0 To 2) As Double
  ZeroZero(0) = 0: ZeroZero(1) = 0: ZeroZero(2) = 0
 'Specify the distance you want to move the raster (midpoint) from 0,0
  Dim DestPnt(0 To 2) As Double
  DestPnt(0) = ZeroZero(0) + 9.83
  DestPnt(1) = ZeroZero(1) + 16.83
  DestPnt(2) = 0
 'Move the clipped raster to it's destination
  RastImg.Move Pnt, DestPnt
