Author Topic: Clip Boundaries for a Raster  (Read 38665 times)
ML
Re: Clip Boundaries for a Raster
« Reply #45 on: November 15, 2007, 02:57:13 PM »
By selecting the lower left and upper right; we already have all the coords that we need
So again, it is just filling in
'Clip boundary = picked points (llpnt and urpnt)
 clipPoints(0) = llpnt(0): clipPoints(1) = llpnt(1)
 clipPoints(2) = llpnt(0): clipPoints(3) = urpnt(1)
 clipPoints(4) = urpnt(0): clipPoints(5) = urpnt(1)
 clipPoints(6) = urpnt(0): clipPoints(7) = llpnt(1)
 clipPoints(8) = llpnt(0): clipPoints(9) = llpnt(1)
with the proper coords
User inputs 10 x 10
We grab that and do 10 -/+ llpnt and urpnt to get the clip boundary, I think :)
I am loosing my ability to think at this point  :-(
ML
« Reply #46 on: November 15, 2007, 03:03:32 PM »
I think what we really need is VBAnonymous Meetings  LOL
Bob Wahr
« Reply #47 on: November 15, 2007, 03:05:18 PM »
Beware the pseudocodiness of it
numbah = thisdrawing.utility.getreal ("How big a square ya after, Bucko?: ")
  clipPoints(0) = mdpnt(0) - numbah/2: clipPoints(1) = mdpnt(1) - numbah/2
  clipPoints(2) = mdpnt(0) - numbah/2: clipPoints(3) = mdpnt(1) + numbah/2
  clipPoints(4) = mdpnt(0) + numbah/2: clipPoints(5) = mdpnt(1) + numbah/2
  clipPoints(6) = mdpnt(0) + numbah/2: clipPoints(7) = mdpnt(1) - numbah/2
  clipPoints(8) = mdpnt(0) - numbah/2: clipPoints(9) = mdpnt(1) + -numbah/2
ML
« Reply #48 on: November 15, 2007, 03:08:33 PM »
Bob; if you keep this up; I will be asking for your phone number LOL; just kidding  :-D
Of course, now I need to go try this  :-)
Bob Wahr
« Reply #49 on: November 15, 2007, 03:11:30 PM »
It's going to take some tweaking, that was just a nudge.  You'll need to bump up your error handling so that it knows what to do when somebody types in something that's not a number.  You might want to put in a default size so they can hit enter to get the default.  You might also want to give them an option to do a rectangle instead of square.  Then again, maybe not.
ML
« Reply #50 on: November 15, 2007, 03:13:02 PM »
That's funny; using the midpoint was my idea originally although I needed your guys help on how to build around it; however I failed to think of that in this (CM's idea) application.
I keep getting stuck on the upper and lower points.
The midpoint is definetely THE most logical place to work from.
So, Hats off to Bob again!  :-)
Maverick®
« Reply #51 on: November 15, 2007, 03:26:48 PM »
Like that hasn't been on how many bar napkins and toilet stalls west of the Mississippi.
Bob Wahr
« Reply #52 on: November 15, 2007, 03:29:00 PM »
A couple of other thoughts to throw out to you.  with the two point selection method, you could just check the distance, round to the nearest whole number, and clip.  For a midpoint centered clip, you can just get them to pick a center point and distance instead of two points.
Bob Wahr
« Reply #53 on: November 15, 2007, 03:29:38 PM »
West of the Mississippi?  I've got national renown.
ML
« Reply #54 on: November 15, 2007, 03:29:51 PM »
WAIT!
Bob
With your code
We will still need
Dim llpnt As Variant 'lower left point
Dim urpnt As Variant 'upper right point
Dim mdpnt(0 To 2) As Double
Dim clipPoints(0 To 9) As Double
With ThisDrawing.Utility
 llpnt = .GetPoint(, vbCrLf & "Select Lower Left Point: ")
 urpnt = .GetPoint(, vbCrLf & "Select Upper Right Point: ")
End With
mdpnt(0) = (llpnt(0) + urpnt(0)) / 2 'Midpoint (X) = (The far left picked point + the far right picked point) / 2
mdpnt(1) = (llpnt(1) + urpnt(1)) / 2 'Midpoint (Y) = (The far bottom picked point + the far top picked point) / 2
mdpnt(2) = 0
To get our midpoint; based off of the picked points in the above code, correct?
So, we get our picked points, figure out the midpnt (all done), then with Bob's "new" code, we get the boundary size;
the boundary size gets divided by 2 and gets built around the midpoint in all 4 directions at that (the divided) size
Very clever!
David Hall
  • Automatic Duh Generator
« Reply #55 on: November 15, 2007, 03:35:04 PM »
Bob is on the right track of what I was thinking.  Bob, how do you do the default thing???  In LISP I know you use <> to define it, but I never learned how in VBA
Bob Wahr
« Reply #56 on: November 15, 2007, 03:35:39 PM »
Did everyone hear the click as the pieces fell into place?
ML
« Reply #57 on: November 15, 2007, 03:36:12 PM »
Bob
Thankfully, I don't swing that way, but I will work for code  :-D
Also, your above idea is also very clever.
Pick center point and get size.
Bob Wahr
« Reply #58 on: November 15, 2007, 03:37:58 PM »
You use error handling with VBA I throw the <crap> into my prompt so it looks familiar to Johnny Caduserguy but it's handle with the error trapping.
ML
« Reply #59 on: November 15, 2007, 03:38:27 PM »
I'm sorry I must have missed it but I hear the click in my e-mail every time there is a new post  :-)
