(setq pt (getpoint "\nPick a point: "))(setq pt2 (getcorner pt "Specify other corner point: "))(command "RECTANGLE" pt pt2)
Pick a point: *Cancel*Pick a point:Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.Command: Specify other corner point: RECTANGLESpecify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]:Specify other corner point or [Area/Dimensions/Rotation]:Command:Command:
