Author Topic: user input in S::Startup  (Read 1627 times)
BazzaCAD
« on: October 18, 2007, 05:52:11 PM »
Can you have a (command) or (getpoint) in S::Startup?
If not is there a workaround?
FengK
Re: user input in S::Startup
« Reply #1 on: October 18, 2007, 06:01:53 PM »
you mean like this?
(defun S::STARTUP (/ pt)
  (setq pt (getpoint "\nPick a point: "))
  (prompt (strcat (vl-princ-to-string pt) "\n"))
  (command)
seems to be working.
BazzaCAD
« Reply #2 on: October 18, 2007, 06:17:42 PM »
Ya I guess it kind of works. I have:
(setq pt2 (getcorner pt "Specify other corner point: "))
(command "RECTANGLE" pt pt2)
And I get:
Pick a point: *Cancel*
Pick a point:
Autodesk DWG.  This file is a TrustedDWG last saved by an Autodesk application
or Autodesk licensed application.
Command: Specify other corner point: RECTANGLE
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]:
Specify other corner point or [Area/Dimensions/Rotation]:
Command:
Command:
Anyone know how to get read of this *Cancel* & Autodesk DWG..... ?
