All these forms were created - from scratch - in the new OpenDCL Beta 1 program!!
![wink :wink:](http://www.theswamp.org/Smileys/black/wink.gif)
This tool "reads" the available door styles in the active drawing.
Form: modeless
Controls: treeview, textbox, blockview, graphic button
problems: none
![](http://www.kbstudio.us/doortool.jpg)
This tool "reads" the available ADT styles in the active drawing. (now if we could get Owen to give us the option of getting rid of the window header this would act just like an un-docked toolbar. In VBA it's thru the API: .ShowCaption = False)
Form: modeless
Controls: combobox, graphic button
problems: none
![](http://www.kbstudio.us/adttoolbar.jpg)
Controls the display of Layers based on Layer States defined in an external standards file.
Form: modeless
Controls: listbox, graphic button, vertical splitter
problems: none
![](http://www.kbstudio.us/LayerStates.jpg)
Collection of View tools - great for working with the PN.
Form: modeless
Controls: listbox, graphic button, textbox
problems: none
![](http://www.kbstudio.us/ViewTools.jpg)
If you press the Import View button this is what you get - imports multiple views.
Form: modeless
problems: none
![](http://www.kbstudio.us/ImportViews.jpg)
Imports Layers from that standards file I was talking about earlier. Uses the Layers filters defined in that drawing to set up the tree view.
Form: modeless
Controls: treeview, listbox, graphic button, vertical splitter
problems: none
![](http://www.kbstudio.us/Importlayers.jpg)
appends text to dims.
Form: modal
Controls: textbox, graphic button
problems: none
![](http://www.kbstudio.us/appenddim.jpg)
Keynoting form. The keynotes are dynamically linked to the file.
Form: modeless
Controls: listbox, graphic button, horiz. splitter, uses the label control for the preview
problems: the splitter is between the listbox and the preview (label control). Everything works as expected until the splitter is moved: then the splitter jumps to the bottom of the form, making the height of the preview 0. I've tried several different configs.
![](http://www.kbstudio.us/keynotes.jpg)
If anyone wants the ODC and LISP files for these projects let me know. Some of them are hooked into ADT so beware. Most are pretty benign . . ..
