Author Topic: Beta 1 - here they are!  (Read 18050 times)
hmspe
Re: Beta 1 - here they are!
« Reply #15 on: March 09, 2007, 11:22:36 AM »
If anyone wants the ODC and LISP files for these projects let me know.  Some of them are hooked into ADT so beware.  Most are pretty benign . . ..   :wink:
I'd love to see the code.  Nothing like working examples to get a head start on learning a new tool.
Martin
"Science is the belief in the ignorance of experts." - Richard Feynman
Guest
« Reply #16 on: March 09, 2007, 01:37:49 PM »
Here's a piccy .. V3.0 for Ac2004-6 Migrated to AC2007-8
Ummm.... Kerry?   Uh....what's a "Buppy" pull-down do??
Guest
« Reply #17 on: March 09, 2007, 01:41:26 PM »
Martin
I'll second that!
James (or anyone else):
I'm assuming there's some sort of GUI for ODC?  If so, can you post a pic (or three)?
From what it looks like, ODC is kinda like LSP hooks up with VBA and has a kid?  Seems pretty cool!
BazzaCAD
« Reply #18 on: March 09, 2007, 01:45:46 PM »
Here's a screen shot of the editor,
https://sourceforge.net/project/screenshots.php?group_id=187950
You should download it & give it a try, after all it's FREEEEEE  :-)
You can download it from the same site.
Check out the "Examples" folder once you get it installed.
Guest
« Reply #19 on: March 09, 2007, 01:51:05 PM »
So when these projects are compiled, what type of file are they and do they load the same way as a LSP or a DVB?
jbuzbee
« Reply #20 on: March 09, 2007, 01:56:15 PM »
Matt,
the form definitions are contained in a .ODC file - think of it like a resource DLL for an ObjectARX routine.  The interaction between AutoLISP and AutoCAD is handled by the OpenDCL.arx (currently versions 16 and 17).  So an "application" would have 3 files: MyApp.lsp, MyApp.odc and OpenDCL.16.arx.  The arx file contains a load function called from lisp: (Odcl_Load_Project "MyApp.odc")
I know it sounds like a lot of files but the benefits are unbelievable!
« Last Edit: March 09, 2007, 01:57:27 PM by jbuzbee »
James Buzbee
Windows 8
BazzaCAD
« Reply #21 on: March 09, 2007, 01:57:36 PM »
They're a custom file type that only OpenDCL can read (.ODC). They don't need to be compiled you just open them in the OpenDCL editor. Then there's an OpenDCL*.ARX that reads the .ODC file & displays it in Acad & provides you with the functions to interact with it via Lisp.
« Reply #22 on: March 09, 2007, 05:16:50 PM »
A little  question : Which software do you use to create your animated gifs?
http://www.techsmith.com/products.asp
Video : Camtasia Studio
Single Piccys : SnagIt
They can be purchased as a bundle.
« Reply #23 on: March 09, 2007, 05:28:32 PM »
http://www.theswamp.org/index.php?topic=15390.msg186804#msg186804
Here's the frontEnd Dialog Piccy :--
Aymen Ellouze
« Reply #24 on: March 10, 2007, 06:08:30 AM »
Thanks Kerry!  :-)
I find them expansive but they are good products!
Tom
« Reply #25 on: March 10, 2007, 07:09:20 PM »
Looking good Kerry
Great work
