Author Topic: My first lisp-DCL "help please"  (Read 5372 times)
Biscuits
« on: February 14, 2007, 02:47:23 PM »
Using Windows XP and ACAD2002 (yes...still).
This is my first attempt at DCL.
The idea is to create isometric mtext with different orientations using a dialogue box.
I tested the lisp by itself and it works great.
I've added the DCL using slide files and it will display fine.
I've managed to cobble this together using several website tutorials and examples.....but
now, I'm lost in making each image activate the corresponding portion of the lisp routine.
Could someone point me in the right direction from here?
;  My lisp file
(defun C:samp4 ()
(mode_tile "image_tiles" 4)
(defun c:LeftPlane (/ PT1)
  (SETQ PT1 (GETPOINT "\nPick Text Insertion Point: "))
   (Command "-Style" "IsoTextL" "Romans" "" "" "-30" "" "" "")
      (initdia) (Command "_.MText" PT1 "J" "MC" "W" "0")
        (Command "Rotate" "Last" "" PT1 "-30")
          (Command "-Style" "STANDARD" "" "" "" "" "" "" "")
(defun c:RightPlane (/ PT1)
    (Command "-Style" "IsoTextR" "Romans" "" "" "30" "" "" "")
        (Command "Rotate" "Last" "" PT1 "30")
(defun c:TopPlaneLeft (/ PT1)
(defun c:TopPlaneRight (/ PT1)
  (setq dcl_id (load_dialog "samp4.dcl"))
  (if (not (new_dialog "samp4" dcl_id)
      );not
    (exit)
  );if
  (setq w (dimx_tile "im")
        h (dimy_tile "im")
  (start_image "im")
  (fill_image 0 0 w h -1)
  (slide_image 0 0 w h "Top_Plane_Left View")
  (end_image)
  (start_image "im1")
  (slide_image 0 0 w h "Top_Plane_Right View")
  (end_image)
  (start_image "im2")
  (slide_image 0 0 w h "LeftPlane")
  (end_image)
  (start_image "im3")
  (slide_image 0 0 w h "RightPlane")
  (end_image)
;  (action_tile "im" "(TopPlaneLeft)")
;  (action_tile "im1" "(TopPlaneRight)")
;  (action_tile "im2" "(LeftPlane)")
;  (action_tile "im3" "(RightPlane)")
    (action_tile
    "cancel"
    "(done_dialog) (setq userclick nil)"
    );action_tile
  (action_tile
    "accept"
    " (done_dialog)(setq userclick T))"
  );action tile
  (start_dialog)
  (unload_dialog dcl_id)
);defun
;  My DCL file
samp4 : dialog {
label = "Isometric Text" ;
     : row {
     : image {
     key = "im" ;
     height =8.0 ;
     width = 30.0 ;
     : image {
     key = "im1" ;
     height =8.0 ;
     width = 30.0 ;
     : row {
      : column {
        :text {
        key = "text1";
        label = "Top Plane - Left View";
        width = 30;
       fixed_width = true;
       alignment = centered;
     : column {
      :text {
        key = "text2";
        label = "Top Plane - Right View";
        width = 30;
       fixed_width = true;
spacer;
spacer;
spacer;
  :row {
     : image {
     key = "im2" ;
     height =8.0 ;
     width = 30.0 ;
     : image {
     key = "im3" ;
     height =8.0 ;
     width = 30.0 ;
     : row {
      : column {
        :text {
        key = "text3";
        label = "Left Side View";
        width = 30;
       fixed_width = true;
     : column {
      :text {
        key = "text4";
        label = "Right Side View";
        width = 30;
       fixed_width = true;
     : row {
     ok_cancel ;
     : row {
     : paragraph {
     : text_part {
     label = "by Yours Truly";
Re: My first lisp-DCL "help please"
« Reply #1 on: February 14, 2007, 03:07:09 PM »
How I would do it is, when the image tiles are selected, they each set the same variable, but to different values.  Or you could have them just hit the image tile, and then have that end the dialog and run the code from there.
(action_tile "im" "(done_dialog 1)")
(action_tile "im1" "(done_dialog 2)")
(action_tile "im2" "(done_dialog 3)")
(action_tile "im3" "(done_dialog 4)")
(action_tile "cancel" "(done_dialog 0)")
(setq DiaResponse (start_dialog))
 ((equal DiaResponse 1)
   (c:TopPlaneLeft)
 ((equal DiaResponse 2)
   (c:RightPlane)
 ((equal DiaResponse 3)
   (c:RightPlane)
 ((equal DiaResponse 4)
   (c:RightPlane)
I have never used images in a dcl file, so this is a guess.  If you do it this way, then you can remove the Okay button.
Edit:  To get this to work you have to change your call to 'image' in the dcl to 'image_button', then selecting them will fire what you want.  I just test it and it worked.  And I fixed the calls to the functions since they are defined with the 'c:' in front which I didn't add the first time.  And fixed a typo.
« Last Edit: February 14, 2007, 03:13:43 PM by T.Willey »
Biscuits
« Reply #2 on: February 14, 2007, 03:49:55 PM »
Thanks "T" got it to work partially.
Should be able to finish it myself.
Thanks for pointing me in the right direction!!
« Reply #3 on: February 14, 2007, 03:55:19 PM »
You're welcome.  Let us know if you need anymore help, and be sure to post the finished code so others can learn from it.  :wink:
efernal
« Reply #4 on: February 14, 2007, 04:09:56 PM »
My sugestions bellow...
;;  My lisp file
;;  Adjustments by Eduardo Fernal : http://www.gr-acad.com.br
;;  14/02/2007 (or 02/14/2007 in USA)
(DEFUN c:samp4 (/ h w dcl_id flag userclick)
  ;; Defined functions...
  (DEFUN c:leftplane (/ pt1)
    (SETQ pt1 (GETPOINT "\nPick Text Insertion Point: "))
    (COMMAND "-Style" "IsoTextL" "Romans" "" "" "-30" "" "" "")
    (INITDIA)
    (COMMAND "_.MText" pt1 "J" "MC" "W" "0")
    (COMMAND "Rotate" "Last" "" pt1 "-30")
    (COMMAND "-Style" "STANDARD" "" "" "" "" "" "" "")
  (DEFUN c:rightplane (/ pt1)
    (COMMAND "-Style" "IsoTextR" "Romans" "" "" "30" "" "" "")
    (INITDIA)
    (COMMAND "Rotate" "Last" "" pt1 "30")
  (DEFUN c:topplaneleft (/ pt1)
    (INITDIA)
  (DEFUN c:topplaneright (/ pt1)
    (INITDIA)
  ;; MAIN ROUTINE...
  ;; See the modifications on the dialog text bellow...
  (IF (> (SETQ dcl_id (LOAD_DIALOG "samp4.dcl"
                        ;|"c:\\listalsp\\myfirstlisp-dcl.dcl"|;
         0
    (IF (NEW_DIALOG "samp4" dcl_id)
      (PROGN
             (SETQ w (DIMX_TILE "im")
                   h (DIMY_TILE "im")
             ;; make your slides in ms/ps, in a viewport x = w and y = h
             ;; this will fill the image_button correctly...
             (START_IMAGE "im0")
             (FILL_IMAGE 0 0 w h -1)
             (SLIDE_IMAGE 0 0 w h "Top_Plane_Left View")
             (END_IMAGE)
             (START_IMAGE "im1")
             (SLIDE_IMAGE 0 0 w h "Top_Plane_Right View")
             (END_IMAGE)
             (START_IMAGE "im2")
             (SLIDE_IMAGE 0 0 w h "LeftPlane")
             (END_IMAGE)
             (START_IMAGE "im3")
             (SLIDE_IMAGE 0 0 w h "RightPlane")
             (END_IMAGE)
             (ACTION_TILE "im0" "(SETQ flag 1)")
             (ACTION_TILE "im1" "(SETQ flag 2)")
             (ACTION_TILE "im2" "(SETQ flag 3)")
             (ACTION_TILE "im3" "(SETQ flag 4)")
             (ACTION_TILE "cancel" "(DONE_DIALOG)(SETQ userclick nil)")
             (ACTION_TILE "accept" "(DONE_DIALOG)(SETQ userclick 1))")
             (START_DIALOG)
             (UNLOAD_DIALOG dcl_id)
             (IF (AND userclick flag)
               (COND ((= flag 0) (c:top_plane_left))
                     ((= flag 1) (c:top_plane_right))
                     ((= flag 2) (c:leftplane))
                     ((= flag 3) (c:rightplane))
               nil
      nil
    (ALERT "Error:\n\n\tUnable to load dialog file...\n\n\t")
  (PRINC)
(PRINC "\n-> Type SAMP4 and press Enter to run...")
(PRINC)
// myfirstlisp-dcl.dcl
samp4
:dialog
label="Isometric Text";
width=68;
fixed_width=true;
:spacer
height=1;
:column
width=61;
height=18;
fixed_width=true;
fixed_height=true;
alignment=centered;
:row
fixed_width=true;
fixed_height=true;
:column
      :image_button
      key="im";
      height =8.0;
      width=30.0;
:text
        key="text1";
        label="Top Plane - Left View";
        alignment=centered;
:column
:image_button
      key="im1";
      height =8.0;
      width=30.0;
      :text
        key="text2";
        label="Top Plane - Right View";
        alignment=centered;
:row
:column
      :image_button
      key="im2";
      height =8.0;
      width=30.0;
      :text
        key="text3";
        label="Left Side View";
        alignment=centered;
:column
:image_button
      key="im3";
      height =8.0;
      width=30.0;
      :text
        key="text4";
        label="Right Side View";
        alignment=centered;
:spacer
height=1;
      ok_cancel;
        :text
label="by Yours Truly";
// end of dialog
<edit: code tags added>
« Last Edit: February 15, 2007, 09:40:59 AM by CAB »
e.fernal
« Reply #5 on: February 15, 2007, 09:42:06 AM »
efernal
Welcome to TheSwamp :-)
« Reply #6 on: February 15, 2007, 09:59:16 AM »
Oops, looks like your flag values don't match, should be this I think.
             (START_DIALOG)
               (COND ((= flag [color=red]1[/color]) (c:top_plane_left))
                     ((= flag [color=red]2[/color]) (c:top_plane_right))
                     ((= flag [color=red]3[/color]) (c:leftplane))
                     ((= flag [color=red]4[/color]) (c:rightplane))
               nil
efernal
« Reply #7 on: February 15, 2007, 01:26:29 PM »
Sorry for the mistake...
You're correct...
Regards,
e.fernal
e.fernal
Biscuits
« Reply #8 on: February 20, 2007, 12:32:27 PM »
Many thanks to you guys for all the help. It's been quite a learning experience getting this one done.
Here is the final product
Now to see if I can attach the image from the printscreen with this code.
Anyone who can use this is welcome to it and modify as you wish.
;;  IsoText lisp file
(DEFUN c:IsoText(/ h w dcl_id flag userclick)
    (INITDIA)
    (INITDIA)
    (INITDIA)
    (INITDIA)
  ;; MAIN ROUTINE...
  (IF (> (SETQ dcl_id (LOAD_DIALOG "IsoText.dcl"
         0
    (IF (NEW_DIALOG "IsoText" dcl_id)
      (PROGN
                   h (DIMY_TILE "im")
             (START_IMAGE "im")
             (FILL_IMAGE 0 0 w h -15)
             (END_IMAGE)
             (START_IMAGE "im1")
             (END_IMAGE)
             (START_IMAGE "im2")
             (END_IMAGE)
             (START_IMAGE "im3")
             (END_IMAGE)
             (START_IMAGE "im4")
             (SLIDE_IMAGE 0 0 w h "Lozier")
             (END_IMAGE)
             (ACTION_TILE "im" "(SETQ flag 1)")
             (START_DIALOG)
               (COND ((= flag 1) (c:topplaneleft))
                     ((= flag 2) (c:topplaneright))
                     ((= flag 3) (c:leftplane))
                     ((= flag 4) (c:rightplane))
               nil
      nil
  (PRINC)
(PRINC "\n-> Type IsoText and press Enter to run...")
(PRINC)
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
DCL portion
IsoText
:dialog
      width=68;
      fixed_width=true;
   :spacer
         height=1;
   :column
         width=61;
         height=18;
         fixed_width=true;
         fixed_height=true;
         alignment=centered;
      :row
            fixed_width=true;
            fixed_height=true;
         :column
                 :image_button
                       key="im";
                       height =8.0;
                       width=30.0;
            :text
                       key="text1";
                         alignment=centered;
         :column
            :image_button
                       key="im1";
                       height =8.0;
                       width=30.0;
                 :text
                       key="text2";
                         alignment=centered;
      :row
         :column
                 :image_button
                       key="im2";
                       height =8.0;
                       width=30.0;
                 :text
                       key="text3";
                         alignment=centered;
         :column
            :image_button
                       key="im3";
                       height =8.0;
                       width=30.0;
                 :text
                       key="text4";
                         alignment=centered;
   :spacer
         height=1;
        ok_cancel;
        :text
         label="by Biscuits (with a little help from my friends)";
   // end of dialog
« Reply #9 on: February 20, 2007, 12:39:40 PM »
Glad you got it working the way you want it to.  :-)  You're welcome for whatever I did.  :wink:
TimSpangler
  • CAD Naked!!
« Reply #10 on: February 21, 2007, 12:44:03 PM »
You could add a sub to show the slide:
;;; ------------ SHOW SLIDE SUB
(defun SHOW_SLIDE ( tile slide / x y)
   (setq x (dimx_tile tile))
   (setq y (dimy_tile tile))
   (start_image tile)
   (fill_image 0 0 x y -15)
   (slide_image 0 0 x y slide)
   (end_image)
Then just call them:
(show_slide "im" "Top_Plane_Left View")
(show_slide "im1" "Top_Plane_Right View")
(show_slide "im2" "LeftPlane")
(show_slide "im3" "RightPlane")
ACA 2015 - Windows 7 Pro
Biscuits
« Reply #11 on: February 21, 2007, 04:39:45 PM »
Thanks Tim.
I'll give it a shot.
« Reply #12 on: February 21, 2007, 05:06:11 PM »
Thanks Tim.
I'm so confused.  :ugly:  I didn't say anything this time, I swear.
j/k.  I know you Tim S.
« Reply #13 on: February 21, 2007, 06:18:56 PM »
Wrong Tim, Tim. :-D
Biscuits
« Reply #14 on: February 22, 2007, 09:01:35 AM »
Sum Tim Wong?
ooohhhhhh.............. is beer thirty and I just got to work
