Author Topic: THEY changed the server !!!  (Read 5078 times)
Hangman
« on: January 22, 2007, 02:25:12 PM »
Aaaagghhhh, ...  help
THEY (the bad guys) changed the server over the weekend.
We have just spent the last four hours trying to fix the mess THEY made for us.
I am in a bit of a pinch and need your help.
I'm not good enough with code to write one quickly that will do what I need.
Can you guys put together a code that will:
Search the drawing for xrefs &/or image files
    Drawings have xrefs & image logo's - some are nested
    If nested, ALERT user of such, nothing more for nested stuff.
check the path of these xrefs &/or image files
    Original path = D:\Drawings ... (Drawings 2005, 2006, or 2007)\ ...
    (The path change was only the drive.  It changed from D: to X:  Everything else in the path is the same)
If the path is D:\Drawings ...
Then change path to X:\Drawings ...
The image logo's are all in the same directory.  The only thing that changed was the drive letter, from D:\ ... to X:\ ...
Uuummm, ... what other info do you need ??
ACAD 2007
Hangman  8)
Re: THEY changed the server !!!
« Reply #1 on: January 22, 2007, 02:29:00 PM »
Would it not be easier to talk to "the bad guys" and have them change the drive mapping back to the way it was? IMO that seems like a much better\easier solution.
Ron
« Reply #2 on: January 22, 2007, 02:45:27 PM »
You might be able to change this to suite your needs.  Right now it doesn't change anything paths, it just lists them.
(defun Testing (/ Doc LayoutCol EndList)
; Returns a list of list of all the Xrefs and Images with their paths within a drawing.
(setq Doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq LayoutCol (vla-get-Layouts Doc))
(vlax-for i LayoutCol
 (vlax-for Obj (vla-get-Block i)
   ((= (vla-get-ObjectName Obj) "AcDbRasterImage")
    (if (not (assoc (vla-get-Name Obj) EndList))
     (setq EndList (cons (cons (vla-get-Name Obj) (vla-get-ImageFile Obj)) EndList))
   ((and (= (vla-get-ObjectName Obj) "AcDbBlockReference") (vlax-property-available-p Obj 'Path))
     (setq EndList (cons (cons (vla-get-Name Obj) (vla-get-Path Obj)) EndList))
EndList
LE
« Reply #3 on: January 22, 2007, 02:49:27 PM »
Ron
Ditto ^^
« Reply #4 on: January 22, 2007, 02:58:36 PM »
Hangman
« Reply #5 on: January 22, 2007, 03:26:04 PM »
They're old farts, set in their ways.  You can't teach an old dog new tricks.
No, it appearantly was the decision of the IT manager and the big man who signs the pay checks.  Their response is, "Deal with it, it's here to stay."
Thanks for the thought though.
To my understanding, they decided to change it when they updated the server because there are too many engineers and others having issues with USB keys and external drives and other things with their laptops that conflict with a servers drive letters being D: E: & F:.  So they decided to move the drive letters to the end of the alphabet so there would be no conflicts with external connections and automapping.
Hangman  8)
Dinosaur
« Reply #6 on: January 22, 2007, 04:01:07 PM »
. . . there are too many engineers and others having issues with USB keys and external drives and other things with their laptops that conflict with a servers drive letters being D: E: & F: . . .
Well, as long as their priorities are straight . . . who should give a rip if production drawings get hosed until multiple manhours are spent cleaning up their mess.
Hangman
« Reply #7 on: January 22, 2007, 04:20:45 PM »
Six hours so far (per drafter) and I have a deadline today, due in two.    Grrrrrr ...   :realmad:
Hangman  8)
jonesy
  • SuperMod
« Reply #8 on: January 22, 2007, 04:27:05 PM »
this thread helped me when our server changed and we lost the xrefs
« Reply #9 on: January 22, 2007, 05:08:49 PM »
You can try this.  It will only work if the path is saved to the xref with the drive letter.
(defun c:ChangeDriveLetters (/ Doc LayoutCol tempPath)
; Change the drives from "D:\" to "X:\" for xrefs and images.
    (and
     (= (strcase (setq tempPath (substr (vla-get-ImageFile Obj) 1 3))) "D:\\")
    (vla-put-ImageFile Obj (strcat "X:\\" (substr tempPath 4)))
    (and
     (= (strcase (setq tempPath (substr (vla-get-Path Obj) 1 3))) "D:\\")
    (vla-put-Path Obj (strcat "X:\\" (substr tempPath 4)))
« Reply #10 on: January 22, 2007, 05:20:37 PM »
All would be okie-dookie if the ``projectname'' variable was set. (please look into it.)
Hangman
« Reply #11 on: January 22, 2007, 06:16:53 PM »
The "projectname" variable for most all my drawings is "".
Hangman  8)
Hangman
« Reply #12 on: January 22, 2007, 06:19:56 PM »
I guess this is what would happen if the "projectname" variable is "".
Command:
Command:
Command: changedriveletters
Command:
Command:
Absolutely noth'n.
« Last Edit: January 23, 2007, 10:34:17 AM by Maverick® »
Hangman  8)
« Reply #13 on: January 22, 2007, 06:23:40 PM »
Command:
Command:
Command:
Command:
Absolutely noth'n.
I don't use projects, so I don't know the variable "projectname".  Did you look at the xrefs after you ran the command?  Did they not change?  If not can you post a small sample drawing? or is it to late?
dan19936
« Reply #14 on: January 22, 2007, 07:40:47 PM »
You can store list of paths to be searched for xref files in the registry. Projectname controls which project paths are used. Look in options under Files > Project Files Search Path to add paths.
If you have a startup routine set the projectname for each drawing, then if the saved xref path isn't found it will look in the registry path list. If the server drive changes you could search/replace the registry to fix the paths (or do it with lisp).
Used to be a command called xpath that would let you change paths for entire directories. Can't seem to get it working in my 2005.
Dan
