Author Topic: xref path edit help needed  (Read 2380 times)
diarmuid
« on: July 24, 2006, 10:33:25 AM »
hi guys help sought,
i have 100+ drawings with on average 5-6 x-refs in each.  the job needs to be moved to another directory under a new job number.  which means the paths need to be changed.  is there a quick xref path edit lisp out there that i could use,  it doen't matter if it needs to run in each drawing, i have a student in for the summer who could to that for me.
thanks in advance
Diarmuid
If you want to win something run the 100m, if you want to experience something run a marathon
hudster
Re: xref path edit help needed
« Reply #1 on: July 24, 2006, 10:34:57 AM »
Autodesk reference manager will do this easily
diarmuid
« Reply #2 on: July 24, 2006, 11:04:23 AM »
thanks for the reply,
we are using acad2002. i'm not sure if the utility that you have mentioned is available with 2002?
is reference manager a stand alone package?
thanks for the prompt reply.
Diarmuid
« Reply #3 on: July 24, 2006, 11:13:38 AM »
thanks in advance
Diarmuid
Maybe look here.  See if this will help you.
« Reply #4 on: July 24, 2006, 11:23:47 AM »
Yes there is a plethora of information here just use the ADVANCED SEARCH entering  xref path.
Here is another link I found
http://www.theswamp.org/index.php?topic=1170.msg15132#msg15132
And another
http://www.theswamp.org/index.php?topic=2370.msg30065#msg30065
PS Tim has become a xref expert, so do check out his new routine.  :-)
« Last Edit: July 24, 2006, 11:31:21 AM by CAB »
« Reply #5 on: July 24, 2006, 11:35:58 AM »
No comment. :wink:
diarmuid
« Reply #6 on: July 26, 2006, 06:19:27 AM »
thanks for the help.
