Author Topic: AutoCAD flavor poll  (Read 13110 times)
David Hall
  • Automatic Duh Generator
Re: AutoCAD flavor poll
« Reply #15 on: October 23, 2006, 03:37:18 PM »
07 Vanilla and XP Pro
As for LT, I would go crazy if I couldn't use VBA
Maverick®
« Reply #16 on: October 23, 2006, 03:38:56 PM »
Above Adesk programmers cubicles....?
If it ain't broke..... put it in a different color box and break it.
craigr
« Reply #17 on: October 23, 2006, 03:40:27 PM »
So can I use my lack of full AutoCad to explain my behavior?
craigr
David Hall
« Reply #18 on: October 23, 2006, 03:43:43 PM »
Im not sure what you mean by that, but I have tried to program everything into a button like LT requires, and  I thought I was going to go crazy.  Its so much easier in VBA or LISP.
craigr
« Reply #19 on: October 23, 2006, 03:48:38 PM »
My recent behavior -
Someone posted some code for me recently that I told them didn't solve my problem. So I chased the problem the long way around the barn to solve my problem. Then, this moring I gave their code another try and it worked fine. - So I humbly apologized & thanked them.
I have found that I can do most of the things I need by programming them into a macro, it's simply a bunch of keystrokes. But you sometimes need to go the long way around the barn to get it done.
This forum has taught me MUCH about how to draw / edit with the keyboard and avoid the popup menus.
I would think that if I did have the full version of AutoCad, I might come up with something to use VBA &/or Lisp, but since I really don't have a need to learn it right now, I again don't know what I am missing.
I thought about learning VBA for MS Word, but haven't yet. Like many other things, I keep putting it off.
craigr
« Last Edit: October 23, 2006, 03:51:28 PM by craigr »
David Hall
« Reply #20 on: October 23, 2006, 03:53:50 PM »
Whats funny about this (not laughing at you, but at myself) is I have no idea what I would use VBA for in Word or Excel.  I can see using Access with forms for data entry, but beyond that, I dont have a clue.
craigr
« Reply #21 on: October 23, 2006, 03:59:53 PM »
I often have 3k & 4K page files that I need to sort for certain information then put in a certain order. I have quite a few macros in MS Word to do some of this, but I have to run them MANY times in a large file. I would like to write a VBA to do this with ONE command rather than have to hit 'CTRL-3' MANY times.
I thought about taking a course at the local community college, but will probably just learn it on my own - like I usually do.
craigr
Birdy
« Reply #22 on: October 23, 2006, 05:16:20 PM »
Same here
I can't use VBA and I do go crazy. ;-)
David Hall
« Reply #23 on: October 23, 2006, 06:12:50 PM »
But this can be fixed
« Last Edit: October 23, 2006, 06:15:56 PM by CmdrDuh »
« Reply #24 on: October 23, 2006, 07:45:49 PM »
Yep, you can get tablets for both ailments now.  Check you email ..
« Reply #25 on: October 23, 2006, 07:46:56 PM »
AC2006, AC2007, Win XP Pro
Kate M
« Reply #26 on: October 24, 2006, 01:46:12 PM »
Needless to say, we consider LT to be nothing but a joke...   :lmao:
It's not a joke -- you just have to know its capabilities and limitations. There are many disciplines for which LT would be inapprpriate, but there are also several for which it works just fine.
deegeecees
« Reply #27 on: October 24, 2006, 01:49:31 PM »
One Line Schematics
Greg B
  • Tell me a Joke!
« Reply #28 on: October 24, 2006, 01:53:58 PM »
Kate - Cruel arn't they?
They just don't understand that you really don't need to spend multi thousands of dollars on a program.
pmvliet
« Reply #29 on: October 24, 2006, 02:00:14 PM »
LT is actually a pretty capable package for the price. Granted 2007LT has gotten pricier as when I bought 2002LT. If you are starting out on your own and want to be legal with software, LT is a very good starting point. I bought 2002LT when I first started as I could afford it a lot easier then the full version. 4 years later, I now had the justification to buy full 2007.
If you are beginning in CAD, LT will serve your purpose for a while. As your expertise gets better and you start streamlining, the full version will then serve it's purpose.
For many companies, LT is more then sufficient. Many companies do not customize or streamline like many of us on TheSwamp.
I'm running 2002LT and 2007 full on XP Pro...
As well as Microstation V8
Pieter
