Author Topic: Example code ( userform, module )  (Read 4566 times)
Re: Example code ( userform, module )
« Reply #15 on: October 17, 2006, 12:09:09 PM »
Try this Mark --
Public Sub RunMe()
    Dim myFormInstance As MyForm
    Set myFormInstance = New MyForm
    With myFormInstance
        .Label1.Caption = "A caption."
        .TextBoxMsg.Text = "Some text."
    End With
    myFormInstance.Show
    Unload myFormInstance
Arizona
« Reply #16 on: October 17, 2006, 12:09:40 PM »
Since you are already displaying the form I believe you need to do a "refresh"
Or put the show form statement under the textbox statements
Never mind...I like Michael's answer better! :-)
« Last Edit: October 17, 2006, 12:11:11 PM by Arizona »
« Reply #17 on: October 17, 2006, 12:10:01 PM »
question, is MyForm part of the dvb that contains RunMe?  if so, you shouldn't have to load it.
2nd thing - I dont know why it doesn't work.  I will go test it
1) yes
2) OK, thanks.
screen shot coming ....
