Author Topic: Example code ( userform, module )  (Read 4307 times)
« on: October 17, 2006, 08:47:13 AM »
Does anyone have some simple code that goes from a module ( function ) -> userform and back again?
thanks for putting up with me folks!
Note to self: remember your VB book tomorrow stupid!
David Hall
  • Automatic Duh Generator
Re: Example code ( userform, module )
« Reply #1 on: October 17, 2006, 08:48:01 AM »
i do, be right back
David Hall
« Reply #2 on: October 17, 2006, 08:51:19 AM »
function or sub?  it shouldn't matter.  Anyway, I couldn't find the exact function I was looking for, but the jist of it is
sub Whatever()
do some stuff
frmFormName.Show
(form does its thing, in the button click event, put me.hide )
Focus returns here
end sub
« Last Edit: October 17, 2006, 09:19:09 AM by CmdrDuh »
« Reply #3 on: October 17, 2006, 09:07:14 AM »
An aside, Mark if you're looking for a reasonable VB book Francesco Balena's "Programming Microsoft Visual BASIC 6.0" <ISBN 0-7356-0558-0> is worthy.
Back to regularly scheduled programming ...
« Reply #4 on: October 17, 2006, 09:29:36 AM »
Thanks Michael
Ok I have this ( see link ) and all works as, I expect it to.
[ http://www.theswamp.org/screens/mark/images/vba_simple_test-1.png ]
So far so good?
David Hall
« Reply #5 on: October 17, 2006, 09:32:57 AM »
MP or Keith might lend a hand here, but I think you would want to change 2 things.  1 would be to make a public sub RunMe instead of a function (Or I could be completely wrong) and 2, does the end in the click event terminate the whole program or just the form?  I thought you would have used a Me.Hide to get rid of the form without exiting the whole program
Hope that helps
« Reply #6 on: October 17, 2006, 09:45:11 AM »
<IMO>
I agree with Cmdr, using End is not a good idea (especially if the code finds it way into a dll down the road - very bad indeed). Best to let the caller instantiate and kill the form. Subtitle: The [Exit] button should just hide the form.
I'll try to code up a little framework for you in a bit, tho it may be a stretch for me (I never code in ACAD VBA, only VB6).
</IMO>
« Reply #7 on: October 17, 2006, 09:53:31 AM »
Something like this then?
Private Sub CommandExit_Click()
    MyForm.Hide
End Sub
David Hall
« Reply #8 on: October 17, 2006, 09:54:58 AM »
Assuming your form name is MyForm then yes, but Me.Hide should work as well.  the Me keyword is nice because VBA knows what has focus, and uses Me in place of MyForm.
« Reply #9 on: October 17, 2006, 10:13:57 AM »
Agreed -- one should avoid hard coding as much as possible. You know C++ right Mark? VB[A]'s 'me' is loosely equivalent to C++/C#'s 'this' (forms are just a specialized class).
« Reply #10 on: October 17, 2006, 10:22:56 AM »
That makes sense!
Thanks guys.
« Reply #11 on: October 17, 2006, 10:43:37 AM »
Thanks guys.
Thank you Mark -- theswamp is the best AutoCAD discussion forum on the net!
David Hall
« Reply #12 on: October 17, 2006, 10:48:40 AM »
ditto
Bar none, the best place to learn Autocad and programming
« Reply #13 on: October 17, 2006, 11:58:46 AM »
OK, quick ( I hope ) question. Why doesn't the following work?
Public Sub RunMe()
    ' test module
    Load MyForm
    MyForm.Show
    MyForm.Label1.Caption = "Hello"          <=== here
    MyForm.TextBoxMsg.Text = "what"        <=== here
    Unload MyForm
    End
End Sub
This of course does.
Private Sub UserForm_Initialize()
    Me.Label1.Caption = "Hello"
    Me.TextBoxMsg.Text = "what"
End Sub
David Hall
« Reply #14 on: October 17, 2006, 12:06:54 PM »
question, is MyForm part of the dvb that contains RunMe?  if so, you shouldn't have to load it.
2nd thing - I dont know why it doesn't work.  I will go test it
