Author Topic: Error handler help needed  (Read 5530 times)
TimSpangler
  • CAD Naked!!
« on: August 09, 2006, 01:10:38 PM »
Ok I have this program that will blink a selected layer.  The problem is that if I hit esc the program will not go to the Reset_env sub to reset the layer color etc.  What it the problem I've been looking at this thing for about an hour.
hl.lsp
;;;    HL.LSP Version 1.1
;;;    Copyright (C) SEPTEMBER, 2001
;;;    Timothy G. Spangler
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice appear in all supporting documents.
;;;    Blinks Selected Layer
(defun wait (seconds / stop)           ; Pause Routine Thanks to Tony
                                       ; Tanzillo
  (setq stop (+ (getvar "DATE") (/ seconds 86400.0)))
  (while (> stop (getvar "DATE"))
;;; End defun
(defun c:hl (/ *error* blink hlini obj off old_cmdecho old_error old_layer
               old_regenmode old_uscicon on path version
            )                          ; Set the Env for Use
  ;; Error Handling Routine
(defun *error* (Msg)
(if (not (member Msg '("Function cancelled" "quit / exit abort")))
(princ (strcat "\n*** Program Error: " (strcase Msg) " ***"))
(princ "\n... Program Cancelled ...")
(while (< 0 (getvar "cmdactive"))
(command)
(RESET_ENV)
(command "_undo" "BE")
  (setq old_cmdecho (getvar "cmdecho"))
  (setq old_layer (getvar "clayer"))
  (setq old_regenmode (getvar "regenmode"))
  (setq old_uscicon (getvar "ucsicon"))
  (setvar "cmdecho" 0)
  (setvar "regenmode" 0)
  (setvar "ucsicon" 0)
  (setq path "C:/Acad Toolbox/Menu Files/Layer Tools/") ;;<-------CHANGE THIS HARD CODED PATH
  (setq obj (car (entsel "\nPick layer to HIGHLIGHT or [ENTER] for Options: ")))
  (if (findfile (strcat path "HL.ini")) ; Begin if
    (progn                             ; Retrieves information from INI
                                       ; file
      (princ "\nRetrieving Configuration...Please Wait. ")
      (wait 0.5)
      (setq hlini (open (strcat path "HL.ini") "r"))
      (read-line hlini)
      (setq version (read-line hlini))
      (read-line hlini)
      (read-line hlini)
      (setq on (atoi (read-line hlini)))
      (read-line hlini)
      (setq off (atoi (read-line hlini)))
      (read-line hlini)
      (setq blink (atof (read-line hlini)))
      (close hlini)
    )                                  ; End progn
    (progn                             ; Creates INI file
      (princ "\nCreating Config file...Please Wait. ")
      (wait 0.5)
      (setq hlini (open (strcat path "HL.ini") "w"))
      (write-line "Configuration File for Highlight Layer Lisp" hlini)
      (write-line "Highlight Layer v1.1  " hlini)
      (write-line "\nBlink On" hlini)
      (write-line "7" hlini)
      (write-line "Blink Off" hlini)
      (write-line "250" hlini)
      (write-line "Blink Speed" hlini)
      (write-line "0.5" hlini)
      (close hlini)
      (setq on 7)
      (setq off 250)
      (setq blink 0.5)
      (setq version "Highlight Layer v1.1  ")
    )                                  ; End progn
  )                                    ; End if
  (pick)
;;; End defun
(defun dialog (/ dcl_id end_dialog)    ; Starts Dialog Session
  (setq DCL_ID (load_dialog "hl.dcl"))
  (if (not (new_dialog "hl" DCL_ID))
    (exit)
  )                                    ; End if
  (image)
  (set_tile "message" version)
  (set_tile "blinker" (rtos blink 2 2))
  (action_tile "blinkon" "(done_dialog 5)")
  (action_tile "blinkoff" "(done_dialog 6)")
  (action_tile "blinker" "(setq blink (atof $value))")
  (action_tile "accept" "(done_dialog 3)")
  (action_tile "cancel" "(done_dialog 4)")
  (setq end_dialog (start_dialog))
  (cond                                ; Begin cond
    ((= end_dialog 5)                  ; Sets blink on color
      (setq on (acad_colordlg 7 nil))
      (dialog)
    ((= end_dialog 6)                  ; Sets blink off color
      (setq off (acad_colordlg 7 nil))
      (dialog)
    ((= end_dialog 3)                  ; <OK>
      (save_ini)
      (setq obj (car (entsel "\nPick layer to HIGHLIGHT: ")))
      (pick)
    ((= end_dialog 4)                  ; <CANCEL>
      (princ "\n User Cancelled!")
  )                                    ; End cond
;;; End defun
(defun pick (/ layr layrcolor)         ; Allows user to select object
  (if (= (type obj) nil)
    (dialog)
    (progn                             ; Begin progn
      (setq layr (cdr (assoc 8 (entget obj))))
      (setq layrcolor (cdr (assoc 62 (tblsearch "layer" layr))))
      (repeat 5                        ; Begin repeat
        (command ".layer" "s" layr "c" on "" "")
        (wait blink)
        (command ".layer" "s" layr "c" off "" "")
        (wait blink)
      )                                ; End repeat
      (princ (strcat "\nThe highlighted layer was:   " layr))
    )                                  ; End progn
  )                                    ; End if
  (reset_env)
;;; End defun
(defun image (/ offcol offhgt offwid oncol onhgt onwid) ; Sets blink on/off
                                       ; color swatches
  (setq onwid (dimx_tile "blinkon"))   ; Begin Blink ON
  (setq onhgt (dimx_tile "blinkon"))
  (setq oncol on)
  (start_image "blinkon")
  (fill_image 0 0 onwid onhgt oncol)
  (end_image)                          ; End Blink ON
  (setq offwid (dimx_tile "blinkoff")) ; Begin Blink OFF
  (setq offhgt (dimx_tile "blinkoff"))
  (setq offcol off)
  (start_image "blinkoff")
  (fill_image 0 0 offwid offhgt offcol)
  (end_image)                          ; End Blink OFF
;;; End defun
(defun save_ini (/ hlini)              ; Saves Confinguration to INI file
  (if (findfile(strcat path "HL.ini")) ; Begin if
      (princ "\nSaving Configuration...Please Wait. ")
      (wait 0.5)
      (setq hlini (open (strcat path "hl.ini") "w"))
      (write-line (rtos on 2 0) hlini)
      (write-line (rtos off 2 0) hlini)
      (write-line (rtos blink 2 2) hlini)
      (close hlini)
    )                                  ; End progn
  )                                    ; End if
;;; End defun
(defun RESET_ENV (/)                   ; Reset env
  (command "_undo" "END")
(setvar "clayer" old_layer)
  (setvar "regenmode" old_regenmode)
  (setvar "ucsicon" old_uscicon)
  (command ".layer" "c" layrcolor layr "")
  (setvar "cmdecho" old_cmdecho)
;;; End defun
;;; Echos to the command line
(princ "\nHighlight Layer v1.1 \n(c)Timothy Spangler, \nSeptember, 2001....loaded.")
;;; End echo
hl.dcl
///    HL.DCL Version 1.0
///    Copyright (C) SEPTEMBER, 2001
///    Timothy G. Spangler
///    Permission to use, copy, modify, and distribute this software
///    for any purpose and without fee is hereby granted, provided
///    that the above copyright notice appears in all copies and
///    that both that copyright notice and the limited warranty and
///    restricted rights notice below appear in all supporting
///    documentation.
///    Used to get information for HL.lsp
hl:dialog{
label = "Layer Highlight Options";
:boxed_column{
label = "On/Off Colors";
:row{
:text{
label = "Blink On Color";
:image_button{
key = "blinkon";
width = 2;
aspect_ratio = 2.5;
:row{
:text{
label = "Blink Off Color";
:image_button{
key = "blinkoff";
width = 2;
aspect_ratio = 2.5;
:boxed_column{
label = "Blinking Speed";
spacer_0;
:edit_box{
label = "Blinking Speed (sec):";
key = "blinker";
width = 2;
fixed_width = true;
spacer_1;
:boxed_row{
    label = "Message...";
      :text{
      key = "message";
     height = 3;
:row{
ok_cancel;
hl.ini
Blink On
41
Blink Off
161
Blink Speed
0.25
ACA 2015 - Windows 7 Pro
Re: Error handler help needed
« Reply #1 on: August 09, 2006, 01:26:09 PM »
What prints to the comamnd line when you hit escape?
« Reply #2 on: August 09, 2006, 01:26:39 PM »
quick guess --
(   (= end_dialog 4)
    (princ \nLoser Cancelled!")
    (RESET_ENV)
TimSpangler
  • CAD Naked!!
« Reply #3 on: August 09, 2006, 01:28:52 PM »
This is what i get
... Program Cancelled ...; error: An error has occurred inside the *error*
functionFunction cancelled
And I not getting anything reset.
/edit: darn fat fingers
« Last Edit: August 09, 2006, 01:32:36 PM by TimSpangler »
« Reply #4 on: August 09, 2006, 01:33:13 PM »
Make the first line in your err handler (vl-bt), reload, re-run and then tell us what you see when you hit <esc>.
Side bet: (command ".layer" "c" layrcolor layr "") call in the reset func, but it's a blind guess.
TimSpangler
  • CAD Naked!!
« Reply #5 on: August 09, 2006, 01:38:36 PM »
This is waht the backtrace gives me:
Backtrace:
[0.58] (VL-BT)
[1.54] (*ERROR* "Function cancelled")
[2.49] (_call-err-hook #<SUBR @086e8488 *ERROR*> "Function cancelled")
[3.43] (sys-error "Function cancelled")
:ERROR-BREAK.38 nil
[4.35] (sys-rtcan-hook)
:KBD-BREAK.31 :KBD-BREAK
[5.28] (WAIT 0.25)
[6.23] (PICK)
[7.19] (C:HL)
[8.15] (#<SUBR @086e8c58 -rts_top->)
[9.12] (#<SUBR @087c2334 veval-str-body> "(C:HL)" T #<FILE internal>)
:CALLBACK-ENTRY.6 (:CALLBACK-ENTRY)
:ARQ-SUBR-CALLBACK.3 (nil 0)
I believe that it is in the Reset sub.  When I comment that line out it just cancels like it should.
<going to look in there>
 Be right back
« Reply #6 on: August 09, 2006, 01:42:53 PM »
(defun RESET_ENV ( )
    (command "_undo" "END")                  ;;  Is undo enabled? Is an undo sequence uncapped?
    (setvar "clayer" old_layer)              ;;  Are varaibles old_layer
    (setvar "regenmode" old_regenmode)       ;;                old_regenmode
    (setvar "ucsicon" old_uscicon)           ;;                old_uscicon
    (command ".layer" "c" layrcolor layr "") ;;                layrcolor, layr
    (setvar "cmdecho" old_cmdecho)           ;;                old_cmdecho
    (princ)                                  ;;  properly set / valid values?
« Reply #7 on: August 09, 2006, 01:43:42 PM »
I second this.  You may have to test that both variables are set before you issue the command.
TimSpangler
  • CAD Naked!!
« Reply #8 on: August 09, 2006, 03:00:40 PM »
Well tried just about everything I can think of.  nothing seems to work.  I created a sub to set everything before the errhandler.  I t seems that if I put anything having to do with (command.... it dumps.  Not sure why.
Don't have anymore time today (well at least til 5:00) to play with it.  I may just rewrite it with some vl stuff.  This thing was originally written in 1999, this was one of my first programs that i wrote.
Thanks guys, if you spot something jsut let me know
« Reply #9 on: August 09, 2006, 03:13:37 PM »
If the error handler is called before the dialog is closed that would cause it to kack -- you cannot invoke command whilst a dialog is active.
TimSpangler
  • CAD Naked!!
« Reply #10 on: August 09, 2006, 03:20:21 PM »
The dialog only opens if enter is hit instead of the selection of an object.  It is only used to set preferances i.e. blinking colors and blinking speed etc., so under normal circumstances there is no dialog.
« Reply #11 on: August 09, 2006, 07:35:39 PM »
Well, I know I've seen dicussions on this before, but I sure can't find anything on it now. But from some testing I've done here, you cannot reliably use (command) within the (*error*) function.
I've rearranged your code so all functions are inside of the main routine (this ensures they all reference the same *error* function) and modified the UNDO marks & resetting of the layer color to use ActiveX instead of (command). It seems to work properly now.
     old_layer old_regenmode old_uscicon
     on path      version LAYR
     LAYRCOLOR wait doc
  (defun RESET_ENV () ; Reset env
   ; (command "_.undo" "_END")
   ;(setvar "ucsicon" old_uscicon)
    (if layr
      ;(command ".layer" "c" layrcolor layr "")
      (vla-put-color (vla-item (vla-get-layers doc) layr) layrcolor)
    (vla-endundomark doc)
    (if (not
    (RESET_ENV)
; Tanzillo
      (exit)
    ) ; End if
    (image)
    (cond ; Begin cond
       (dialog)
       (dialog)
       (save_ini)
       (pick)
    ) ; End cond
;;; End defun
  (defun pick () ; Allows user to select object
      (dialog)
  (wait blink)
  (wait blink)
) ; End repeat
      ) ; End progn
    ) ; End if
    (reset_env)
;;; End defun
; Sets blink on/off
; color swatches
    (setq oncol on)
    (setq offcol off)
;;; End defun
(wait 0.5)
(write-line
  hlini
(close hlini)
      ) ; End progn
    ) ; End if
;;; End defun
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  ;(command "_undo" "BE")
  (vla-startundomark doc)
  (setq path "C:/Base Maps/Jeffs Test Files/Test Lisp/")
  (setq
    obj (car
; file
      (wait 0.5)
      (read-line hlini)
      (read-line hlini)
      (read-line hlini)
      (read-line hlini)
      (read-line hlini)
      (close hlini)
    ) ; End progn
      (wait 0.5)
      (write-line
hlini
      (close hlini)
      (setq on 7)
      (setq off 250)
      (setq blink 0.5)
    ) ; End progn
  ) ; End if
  (pick)
;;; End defun
;;; End defun
(princ
;;; End echo
GDF
« Reply #12 on: August 10, 2006, 10:35:03 AM »
Tim and Jeff
That is pretty slick. I have one similar to it that I can now clean up.
Tim thanks for sharing it.
My code that needs to be cleaned up.
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; View Layer ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun VIEWLAYIT  (/ tmp)
  (initget "F V")
  (setq tmp (getkword "\n* Select View type:  <F>lash   <V>iewlay *"))
  (cond ((or (= tmp "V") (= tmp nil)) (VIEWLAYSIT))
        ((= tmp "F") (LAYFLASHITX)))
  (princ))
(defun VIEWLAYSIT  (/ dcl_id ll x no)
  (setq dcl_id (load_dialog (strcat ARCH#LAYF "ARCH_LAYS.DCL")))
  (defun ALERT1  (MSG)
    (new_dialog "alert1" dcl_id "0" (list 400 750))
    (set_tile "set-title" (strcat ARCH#LOGO " : Layer Checking Dialog"))
    (set_tile "alert1" MSG)
    (action_tile "accept" "(done_dialog 1)")
    (action_tile "cancel" "(exit)")
    (start_dialog)
    (princ))
  (defun LAYL  ()
    (setq LL NIL
          LL (list (cdr (assoc 2 (tblnext "LAYER" t))))
          X  (tblnext "LAYER"))
    (while (/= NIL X)
      (setq LL (append LL (list (cdr (assoc 2 X))))
            X  (tblnext "LAYER")))
    LL)
  (setq NO 1
        LL (LAYL))
  (ALERT1
    (strcat "Their are " (itoa (length LL)) " Layer(s) in this Drawing."))
  (setvar "CLAYER" "0")
  (command "zoom" "e")
  (command "layer" "off" "*" "" "")
  (repeat (1- (length LL))
    (progn (command "layer" "on" (nth NO LL) "")
           (ALERT1 (strcat "Displayed Layer : " (nth NO LL)))
           (command "Layer" "off" (nth NO LL) "")
           (setq NO (1+ NO))))
  (command "LAYER" "ON" "0" "")
  (ALERT1 (strcat "Displayed Layer : 0  <Viewing Completed>"))
  (command "LAYER" "ON" "*" "")
  (command "zoom" "p"))
(defun LAYFLASHITX  (/ LAYLST)
  (setq LAYOBJ (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
               ;;MATCH   (strcase (getstring "\n* Enter Layer match string: *"))
  (setq MATCH
         (cdr
           (assoc 8
                  (entget
                    (car (entsel "\n* Select an Layer to Flash: <escape to cancel> *"))))))
  (repeat 10000
    (vlax-for
           FOR-ITEM  LAYOBJ
      (if (wcmatch (strcase (vla-get-name FOR-ITEM)) MATCH)
        (progn (vla-put-layeron FOR-ITEM :vlax-true))))
    (repeat 5000 (princ))
    (vlax-for
           FOR-ITEM  LAYOBJ
        (vla-put-layeron FOR-ITEM :vlax-false)))
    (repeat 5000 (princ))))
//VIEWLAY
alert1 : dialog {key="set-title"; initial_focus="accept";
  :boxed_column {children_fixed_width=true; children_fixed_height=true;
    :row {
      :button {label=">>"; key="accept"; is_default=true;}
      :spacer {}
      :text_part {key="alert1"; alignment=centered; width=40; height=1.25; fixed_width_font=true;}
      :button {label="X"; key="cancel"; is_default=true;}
    :spacer {}
Gary
« Reply #13 on: August 10, 2006, 11:07:55 AM »
Good stuff you guys.
Additional food for thought.
Sorry for the aberrant brevity / wish I could play in this thread, but duty calls.
« Reply #14 on: August 10, 2006, 11:18:05 AM »
'kay,managed about 2 minutes on this so bear with me. Consider the implications of this little demo (no time to spell it out) --
(defun c:Demo ( / ini end foo main )
    (defun ini ( )
        (princ "Intializing ...\n")
    (defun end ( )
        (princ "Terminating ...\n")
    (defun foo ( / result )
        (vl-catch-all-apply
           '(lambda ( )
                (vl-some '(lambda (x) (setq result x))
                    (list
                        (getint
                            (strcat
                                "Enter an integer value, "
                                "[Enter] for the default <42>, "
                                "or <[Esc] to bail: "
                        42
        result
    (defun main ( / num )
        (ini)
            (   (setq num (foo))
                (princ
                    (strcat
                        "Let's roll with "
                        (itoa num)
                        " ...\n"
                ;;  do other stuff ...
            (   t
                (princ
                    (strcat
                        "Ok, uncle, user "
                        "doesn't want to play.\n"
        (end)
    (main)
Bye!
