I've changed my mind about the setvars function, though I'll leave existing posts as is.
I think error trapping the individual setvar calls is a bad idea. I started to think about that approach as applies to my "real world" programming and I could not think of a single instance where I would want to mask a setvar error, that is, prevent a program from crashing. The simple reason being (for me) that a failed setvar call represents a design flaw in my program (either the variable name is wrong or the candidate value is invalid) so I'd actually want it to trash the program (so I could code it proper). As a result I would alter the setvars function to act accordingly --
(defun setvars ( lst )
(mapcar
'(lambda ( var val ) (list var (getvar var) (setvar var val)))
(mapcar 'car lst)
(mapcar 'cadr lst)
Argument lst is (still) of the form '(("var" val)("var" val)), for example '(("cmdecho" 0)("regenmode" 1)).
The result is of the form form '(("var" oldval newval), for example '(("cmdecho" 1 0)("regenmode" 0 1)) so it can still be passed to the setvars function later, say at the end of program execution.
I realize this thread has become a ghost town <not sure how I killed it, tmi?> and I'm talking to myself but that's ok, point is still valid.
