Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Reset system variables to default value
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Reset system variables to default value (Read 3472 times)
matrix2005in
Guest
on:
June 25, 2006, 02:48:52 PM »
does anyone have a code for reset all/Major system variables in AutoCAD to its default value....and it should be of AutoCAD 2000 not for 2006/07 i know they added more sysvars in latest versions..i am using AutoCAD 2000i
thanks
mathew
Logged
MickD
King Gator
(x-in)->[process]->(y-out) ... simples!
WWW
Re: Reset system variables to default value
Reply #1 on:
June 25, 2006, 06:24:53 PM »
Does setting the profile to <<Unnamed Profile>> set them all back to default??
Perhaps you can then make another profile or save these default settings somewhere for later use.
Logged
- John Carmack
- J.R.R. Tolkien
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #2 on:
June 25, 2006, 08:14:57 PM »
Using Express Tools is one way ..
Logged
Andrea
Water Moccasin
WWW
Reply #3 on:
June 28, 2006, 09:39:19 AM »
Quote from: Kerry Brown on June 25, 2006, 08:14:57 PM
this will save a file to SVF format..
you can also rename it in SCR and run SCRIPT.
Logged
Keep smile...
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
