Author Topic: Reset system variables to default value  (Read 3491 times)
matrix2005in
« on: June 25, 2006, 02:48:52 PM »
does anyone have a code for reset all/Major  system variables in AutoCAD to its default value....and it should be of AutoCAD 2000 not for 2006/07 i know they added more sysvars in latest versions..i am using AutoCAD 2000i
thanks
mathew
MickD
Re: Reset system variables to default value
« Reply #1 on: June 25, 2006, 06:24:53 PM »
Does setting the profile to <<Unnamed Profile>> set them all back to default??
Perhaps you can then make another profile or save these default settings somewhere for later use.
- John Carmack
- J.R.R. Tolkien
« Reply #2 on: June 25, 2006, 08:14:57 PM »
Using Express Tools is one way ..
Andrea
« Reply #3 on: June 28, 2006, 09:39:19 AM »
this will save a file to SVF format..
you can also rename it in SCR and run SCRIPT.
Keep smile...
