I've just started getting into the new(
-ish) Autoloader system for 2012+ versions, in advance of our upgrade to 2014 later this year... While 'practicing' how to configure
PackageContents.xml, I thought it would serve as dual purpose to setup some of these .bundle packages for apps I use daily in 2011, that are also compatible with 2012, 2013, etc..
I did not develop these particular plug-ins, but they are all freely available, and I made sure to include a shortcut to each of the source website where I found them... I just haven't found them available in .bundle format, and thought this thread might serve as a place for us to share our work, or as I am doing here, tools that are freely available and just not setup for the Autoloader system yet.
Autodesk DWG ArxDBG.bundleI could not find this in .bundle format, so I assembled the package IAW
this blog post.
2016-01-04 - Revised the app to support up to 2016 version, thanks to Owen's work
here.
Autodesk DWG MgdDBG.bundleGiven that ArxDbg was not available, I initially created this .bundle myself also, until I stumbled upon the published .bundle in
this blog post, who's source is now being used.
2016-01-04 - Revised the app to support up to 2016 version, thanks to Gile's work
here.
BizIcom-iDwgTab.bundle - Removed until written authorization to share is obtainedI created the .bundle from the plug-in I've been using since reading
this post.
