Author Topic: Paste without Formating  (Read 2007 times)
Willie
  • Going nowhere slowly
« on: September 04, 2007, 09:49:14 AM »
Is there a way to paste text, copied in Excel or Word, without any formating into and Mtext object?
At the moment, I am doing it this way:
1. Copy text in Excel
2. Paste into Notepad - to remove all the formating
3. Copy the text in Notepad
4. Paste the into Mtext
I allways use CTRL+TAB and CTRL+C and CTRL+V to speed this up, but it is not fast enough.
Any suggestions?
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
deegeecees
Re: Paste without Formating
« Reply #1 on: September 04, 2007, 10:08:47 AM »
You can set your default text editor to Notepad, that would eliminate a step...
craigr
« Reply #2 on: September 04, 2007, 11:39:38 AM »
Any suggestions?
That's the way I do it, and I agree - it's too slow.
Sorry I don't have the answer but look forward to hearing one if it exists.
craigr
deegeecees
« Reply #3 on: September 04, 2007, 11:47:51 AM »
This way, you would do the following:
1. Copy test in Excell
2. Select/Create Mtext object
3. Paste
4. Click OK.
Done
Willie
« Reply #4 on: September 05, 2007, 05:12:07 AM »
Thanks for all the replies.
For general Mtext creation and editing, Notepad is not the first choice, but for the formatless pasting of text Notepad is the answer.
I will try to create a toggle buttun to switch between the Internal and Notepad to switch between Notepad and the Internal editor.
Willie
« Reply #5 on: September 05, 2007, 07:09:48 AM »
My command to toggle between Notepad and the Internal editor
(defun c:TTE ()
  (setq notep "c:/windows/notepad.exe")
  (setq inter "Internal")
  (setq cur_mtexted (getvar "MTEXTED"))
    (or
      (= cur_mtexted null)
      (= cur_mtexted "Internal")
    );or
       (setvar "MTEXTED" notep)
       (princ "\n ***************************************")
       (princ "\n *** MText editor changed to NOTEPAD ***")
     );progn
       (setvar "MTEXTED" inter)
       (princ "\n ****************************************")
       (princ "\n *** MText editor changed to INTERNAL ***")
     );progn
    );if
  );defun
Thanks to deegeecees for giving me the idea
Willie
deegeecees
« Reply #6 on: September 05, 2007, 09:58:07 AM »
Looks good Willie, you're welcome.
Sdoman
« Reply #7 on: September 14, 2007, 12:20:00 AM »
I use a little utility by Steve Miller called "Pure Text".  It strips formatting from the contents of the clipboard and paste it into the current document via the hotkey Windows+V.  It's free!
http://stevemiller.net/puretext/
