Author Topic: Help! CUI in read only  (Read 3657 times)
Zykl0
« on: April 01, 2009, 04:28:09 PM »
Hello i have problem i cannot modify anymore my CUI
everything is greyed out,
please help!!
Matt__W
  • I like my water diluted.
Re: Help! CUI in read only
« Reply #1 on: April 01, 2009, 04:30:21 PM »
Is it the Main or Enterprise file?  And do you have read/write access to wherever it's stored?
Autodesk Expert Elite
« Reply #2 on: April 01, 2009, 04:30:32 PM »
please help!!
could it be that the ENTERPRISE CUI is current?
Zykl0
« Reply #3 on: April 01, 2009, 04:32:36 PM »
omg, this UI is stored in the network and i installed it on a co-worker computer. maybe its the problem?
should i copy the CUI file elsewhere and reload it?
Matt__W
« Reply #4 on: April 01, 2009, 04:38:33 PM »
What??  Are you saying you copied the file from the network to his/her computer?  Is the read-only attribute toggled on?
Zykl0
« Reply #5 on: April 01, 2009, 04:41:02 PM »
No, there is no read only attribute checked on the file
i simply loaded my CUI (saved on network) (loaded from network)
on co-worker computer, and transfered some toolbar to his computer.
i dont see how this could pu the file on read only.
Kate M
« Reply #6 on: April 01, 2009, 06:33:07 PM »
Under the Options dialog, look at the paths for Customization files. If you want to edit the CUI, put it in the Main path, not the Enterprise path.
Zykl0
« Reply #7 on: April 02, 2009, 08:08:43 AM »
i have this exact setting, and acad still in read only, this is annoying,
should i create a fresh copy of each .cui file for every user in the company?
i dont know if its the problem i installed custom toolbar many time to different computers and i never got any read only problem :(
craigr
« Reply #8 on: April 02, 2009, 11:44:27 AM »
You can Share CUI Files over a Network!!?
Does this mean that if we were to do it this way, when I write a new Macro / icon, it would show up on another's workstation the next time they start CAD?
This would be WONDERFUL if this could be done!
craigr
Zykl0
« Reply #9 on: April 02, 2009, 11:55:28 AM »
I installed my CUI on many computer today (i still cant edit it from my computer) but i can edit it from the last computer i installed on it.
still annoying, i'm the only one in my company able to modify that and i cant open it :(
« Reply #10 on: April 02, 2009, 12:02:16 PM »
craigr
yes you can
