http://www.theswamp.org/index.php?topic=54165.new#newIt is actually my save code. when i save the dwg with my customer save and i reopen the dwg, I get the recovery prompt.I never had an issue with this code till now.any suggestions?
Does it occur when you start a new 2019 template, save, and reopen?
Does the error occur with a previously saved drawing or with a newly named drawingor both ?
Quote from: andrew.. on May 04, 2018, 02:06:18 PMhttp://www.theswamp.org/index.php?topic=54165.new#newIt is actually my save code. when i save the dwg with my customer save and i reopen the dwg, I get the recovery prompt.I never had an issue with this code till now.any suggestions?Update your code, or don't use it...does the Recovery Prompt go away IF you don't use the code you mention in the post I quoted?
Post the code, let's all have a look at it.
i do not get a recovery prompt if i dont use my custom code.I have used this custom command for a few years. never been an issue till the new version
