Author Topic: save dwg code causing acad 2019 to prompt for dwg recovery when opening any dwg  (Read 1865 times)
andrew..
does anyone see anything wrong with the code below?
when i open any dwg after saving it, it prompts for dwg recovery.
If i disable this and run the OOTB save, I do not get the recovery prompt.
This code has never been an issue till now.
(defun c:nsave (/ activedoc docfullname backuppath archivename dwgbakk)
(if (= (getvar "dwgtitled") 0)
 (PROGN
   (initdia)
  (if (>= (atof (getvar "acadver")) 20.0)
   (command-S ".saveas")
   (command ".saveas")
  (setq activedoc (vla-get-activedocument (vlax-get-acad-object)))
(vla-save activedoc)
  (if (and (not (= 0 (strlen (setq docfullname (vla-get-fullname activedoc)))))
           (setq backuppath "C:\\ACADBACK\\")
           (setq archivename (strcat backuppath (vl-filename-base (vla-get-name activedoc))".dwg"))
    (setq dwgbakk (vl-file-copy docfullname archivename))
    (alert "Ooooops. Unable to get Filename.")
  (if (= dwgbakk nil)
(vl-file-delete archivename)
  (prompt (strcat "\n\nFile Saved..." archivename ))
  (prompt (strcat "\n\nFile Saved..." docfullname))
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
You have no course of action that works as expected if the backuppath does not exist.
Otherwise I can see no obvious cause for error.
Called Kerry in my other life
I live at UTC + 13.00
