Author Topic: autocad 2019 propmpting for dwg recovery when opening dwgs  (Read 7315 times)
andrew..
When I open any dwg, either older dwgs or dwgs created in 2019, when I close them and then go to reopen them
I am being prompted for dwg recovery everytime.
Anyone else have this issue or have a suggestion on why this is?
Is it a new thing in 2019?
ChrisCarlson
Re: autocad 2019 propmpting for dwg recovery when opening dwgs
« Reply #1 on: May 04, 2018, 01:23:00 PM »
Does it occur when you start a new 2019 template, save, and reopen?
rkmcswain
« Reply #2 on: May 04, 2018, 01:23:49 PM »
Is this plain AutoCAD or a vertical app?
andrew..
« Reply #3 on: May 04, 2018, 02:06:18 PM »
http://www.theswamp.org/index.php?topic=54165.new#new
It is actually my save code. when i save the dwg with my customer save and i reopen the dwg, I get the recovery prompt.
I never had an issue with this code till now.
any suggestions?
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #4 on: May 04, 2018, 04:30:05 PM »
Andrew,
It may help if you answer the requests for information from people trying to assist you in this matter.
Regards,
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
« Reply #5 on: May 04, 2018, 04:32:04 PM »
Does the error occur with a previously saved drawing
or with a newly named drawing
or both ?
« Reply #6 on: May 04, 2018, 06:00:01 PM »
any suggestions?
Update your code, or don't use it...does the Recovery Prompt go away IF you don't use the code you mention in the post I quoted?
andrew..
« Reply #7 on: May 07, 2018, 01:35:02 PM »
it happens when i use my custom save command.
If i start a new file and save with my custom save command and close it and open it again. i get this recovery prompt
if i open an old file i get the recovery prompt.
If it run the recovery on any of these dwgs and save with the OOTB save command and reopen it. i get NO recovery prompt.
andrew..
« Reply #8 on: May 07, 2018, 01:35:39 PM »
or both ?
both it appears any dwg saved with my custom save is causing this
andrew..
« Reply #9 on: May 07, 2018, 01:37:00 PM »
any suggestions?
correct.
i do not get a recovery prompt if i dont use my custom code.
I have used this custom command for a few years. never been an issue till the new version
pendean
  • Mosquito
  • "I am not a number, I am a free man"
« Reply #10 on: May 07, 2018, 01:51:11 PM »
Post the code, let's all have a look at it.
kdub_nz
  • SuperMod
« Reply #11 on: May 07, 2018, 04:10:44 PM »
The code is here : http://www.theswamp.org/index.php?topic=54165.msg587819#msg587819
andrew: I meant to ask ;
What happens if you add Audit the drawing after you save it with your routine?
and, are you still using the same routine?
pendean
  • Mosquito
« Reply #12 on: May 08, 2018, 08:57:55 AM »
Andrew...
Why do you need the ver.20 check in the code?
What dwg-version are you saving your files to in R2019?
It's appears either no one here has R2019 or no one wants to try your code on their PC: are you simply trying to save your file in two locations at the same time?
steve.carson
« Reply #13 on: May 08, 2018, 10:09:35 AM »
FWIW, your code works as I would expect on my C3D2018 (don't have 2019 installed). No recovery messages, only creates the backup if C:\ACADBACK\ exists.
pendean
  • Mosquito
« Reply #14 on: May 08, 2018, 04:06:14 PM »
Lisp works fine here in R2019 as well: wonder what other settings Andrew.. has that we do not.
