WAIT!
Bob
With your code
numbah = thisdrawing.utility.getreal ("How big a square ya after, Bucko?: ")
clipPoints(0) = mdpnt(0) - numbah/2: clipPoints(1) = mdpnt(1) - numbah/2
clipPoints(2) = mdpnt(0) - numbah/2: clipPoints(3) = mdpnt(1) + numbah/2
clipPoints(4) = mdpnt(0) + numbah/2: clipPoints(5) = mdpnt(1) + numbah/2
clipPoints(6) = mdpnt(0) + numbah/2: clipPoints(7) = mdpnt(1) - numbah/2
clipPoints(8) = mdpnt(0) - numbah/2: clipPoints(9) = mdpnt(1) + -numbah/2
We will still need
Dim llpnt As Variant 'lower left point
Dim urpnt As Variant 'upper right point
Dim mdpnt(0 To 2) As Double
Dim clipPoints(0 To 9) As Double
With ThisDrawing.Utility
llpnt = .GetPoint(, vbCrLf & "Select Lower Left Point: ")
urpnt = .GetPoint(, vbCrLf & "Select Upper Right Point: ")
End With
mdpnt(0) = (llpnt(0) + urpnt(0)) / 2 'Midpoint (X) = (The far left picked point + the far right picked point) / 2
mdpnt(1) = (llpnt(1) + urpnt(1)) / 2 'Midpoint (Y) = (The far bottom picked point + the far top picked point) / 2
mdpnt(2) = 0
To get our midpoint; based off of the picked points in the above code, correct?
So, we get our picked points, figure out the midpnt (all done), then with Bob's "new" code, we get the boundary size;
the boundary size gets divided by 2 and gets built around the midpoint in all 4 directions at that (the divided) size
Very clever!
