Author Topic: Freeze all layer  (Read 6026 times)
Re: Freeze all layer
« Reply #15 on: April 27, 2006, 03:01:44 PM »
Thanks for the input MP. Why do you prefer the getvar over activex?
This stuff is finally starting to get fun for me :).
Ron
« Reply #16 on: April 27, 2006, 03:02:33 PM »
1.Thanks for the input MP.
2.Why do you prefer the getvar over activex?
3.This stuff is finally starting to get fun for me :).
Ron
1. My pleasure.
2. The brevity.
3. Most excellent!
Sdoman
« Reply #17 on: April 27, 2006, 08:50:09 PM »
Gotta go with Steve on this one.  Humbertogo, can you post the whole code you're using??
Thanks CADaver.  The way I/we interpreted the Op's question is that his original code works (he says so).  The problem he is having is with the *error* function.  I assume that the Op's code is part of a routine which crashes when the user cancels or the routine ends.
The other view, is that the Op's code does not work and is causing the *error* function to execute.  And thus appears to be an error in the *error* function, but this error should be capture while freezing the layers and therefore avoiding the error in the *error*. Whew..
Anyhow, it interesting to see so many ways to "skin a cat".  I just not sure what cat we should be skinning...  :-)
Jürg Menzi
  • Oberegg, Switzerland
« Reply #18 on: April 28, 2006, 03:10:58 AM »
Not sure if the local var is needed. If not then this.
There is no need for a lokal var.
In my apps the acaddoc object is global, therefore I've to copy this line to the extracted samples... ;-)
MENZI ENGINEERING GmbH
CADaver
« Reply #19 on: April 28, 2006, 08:18:38 AM »
That's why I'd like to see the original code.  I've beat myself silly for hourss over something as simple as misspelling the word command.
