Author Topic: folder network write permission...  (Read 3490 times)
Andrea
« on: April 26, 2006, 01:32:07 PM »
Hi all,..
I would like to know if it is possible in LISP to know if the current user have
some write permission in a specific folder..
for the moment i use this...
(setq filetemp (open (strcat setupfolder "\\" DEPARTEMENT "\\test.txt") "w"))
(close filetemp)
(if (findfile (strcat setupfolder "\\" SDC_DEPARTEMENT "\\test.txt"))
  (progn.....
but work only for who have write permission....
Keep smile...
ElpanovEvgeniy
  • Moscow (Russia)
Re: folder network write permission...
« Reply #1 on: April 26, 2006, 01:48:34 PM »
Try so:
(vl-file-copy
  (strcat (getenv "tmp") "\\test.txt")
) ;_  vl-file-copy
(setq filetemp (open (strcat (getenv "tmp") "\\test.txt") "w"))
(close filetemp)
« Reply #2 on: April 26, 2006, 01:49:03 PM »
Quick and dirty --
(defun IsFolderWriteable ( foldername )
    (and
        (vl-file-directory-p foldername)
        (   (lambda ( tempfilename / handle )
                (if (setq handle (open tempfilename "w"))
                        (close handle)
                        (vl-file-delete tempfilename)
                        t
            (vl-filename-mktemp "yaqada" foldername ".yep")
Andrea
« Reply #3 on: April 26, 2006, 02:16:49 PM »
Try so:
(vl-file-copy
) ;_  vl-file-copy
(close filetemp)
thanks...ElpanovEvgeniy
But If I understand your code..
You copy the test.txt file from network to local...and than see if we can open from there !!?
hmm...not realy what i need...
But you give me some hint...
(setq filetemp (strcat setupfolder "\\" DEPARTEMENT "\\test.txt"))
(setq Fre (vl-file-copy currentexistingfile filetemp))
(if Fre
  (vl-file-delete filetemp).....
Thanks...
I have lurn another think....again...;-)
« Last Edit: April 26, 2006, 02:40:24 PM by Andrea »
Keep smile...
« Reply #4 on: April 26, 2006, 03:36:12 PM »
Another dick and quirty just for fun --
    (and
        (   (lambda ( fso / result )
                (setq result
                    (zerop
                        (logand 1
                            (vlax-get
                                (vlax-invoke fso 'GetFolder foldername)
                                'Attributes
                (vlax-release-object fso)
                result
            (vla-getinterfaceobject
                (vlax-get-acad-object)
                "Scripting.FileSystemObject"
« Reply #5 on: April 26, 2006, 05:39:36 PM »
Edit: added missing local declaration.
I believe that first version may cause a memory leak because the implied folder object is not formally released. I'm leaving it intact for conversation sake.
Here's a variant that does formal cleanup --
    (and
        (   (lambda ( / fso folder result )
                (setq result
                    (zerop
                        (logand 1
                            (vlax-get
                                (setq folder
                                    (vlax-invoke
                                        (setq fso
                                       'GetFolder
                                        foldername
                                'Attributes
                (vlax-release-object folder)
                result
« Last Edit: April 26, 2006, 05:46:40 PM by MP »
Sdoman
« Reply #6 on: April 28, 2006, 03:25:49 PM »
    (and
Nice function MP.  I am curious however, as to why you used Lambda in this situation?  Typically, I see it used as an argument to Mapcar or Apply.
« Reply #7 on: April 28, 2006, 08:32:40 PM »
1.One could use progn, but the parent code would have to declare the locals -- not necessarily a bad thing, but more and more I try to utilize discrete blocks of code / logic.
2.Down the road if one wished to extract that portion of the code to use as a separate function it's already formed (self contained) as such.
3.It's clean to me in an inexplicable way, but I fully admit -- I'm kinda funny that way.
:loco:
Thanks Steve.
Sdoman
« Reply #8 on: April 30, 2006, 12:37:25 AM »
I see the wisdom now.   Very creative usage.  Thanks for the lesson.
« Reply #9 on: April 30, 2006, 10:59:31 AM »
Thank you Steve -- very generous comments.
