Author Topic: Getting the angle ...  (Read 2552 times)
Hangman
« on: April 13, 2006, 06:15:23 PM »
How can I get an angle of two defined points ??
an example:
(setq A (getpoint ... ))
(setq B (getpoint ... ))
(setq ang1 (getangle A B))
This gives an error as getangle is waiting for user input.
I can't give user input to get the angle.  Any ideas to get this angle ??
Thanks.
Hangman  8)
Re: Getting the angle ...
« Reply #1 on: April 13, 2006, 06:19:59 PM »
Perhaps try
(SETQ A    (GETPOINT)
      B    (GETPOINT)
      ang1 (ANGLE A B)
Jürg Menzi
  • Oberegg, Switzerland
« Reply #2 on: April 13, 2006, 10:18:46 PM »
getangle...
asks you for two points or a numeric angle
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
« Reply #3 on: April 13, 2006, 11:26:51 PM »
just to clarify Jürg's post, try these ...
(setq ang2 (getangle "\nSelect 2 points"))
(setq ang3 (getangle "\nEnter decimal degrees to convert to radians. "))
and compare them with the previously posted functionality.
Jürg Menzi
« Reply #4 on: April 14, 2006, 09:30:35 AM »
Thanks Kerry,
early in the morning after a birthday party :doa:
I was not in the mood to write a comprehensive explanation...
Hangman
« Reply #5 on: April 14, 2006, 03:27:41 PM »
Thanks Kerry.  Now that you've mentioned the
(SETQ A    (GETPOINT)
        B    (GETPOINT)
        ang1 (ANGLE A B)
I have found this all reference all over the place.  I'm a blind draftsman.   8-)
Anyhow, my sitiation is that I have two points from a previous creation.  So I can't ask the user to pick the two points for the angle.  Your post was most helpful.  Thanks again.
Hangman  8)
