i have this code which works great but i would like to make improve it so the user can input their units in any format. e.g. instead of .125 they could enter 1/8. i usually type it in decimal form but not everyone does and it will use the previous distance if you don't use decimal format.
(defun c:DOF (/ a b b1 p1 d pckbox)
(setq d 20 p1 nil pee (/ pi 2)e 3 pckbox (getvar "pickbox")line " ")
(if(= #parof nil)(setq #parof(/(getvar "viewsize")10)))
(princ "\nCurrent offset <")(princ #parof)
(setq answer(getstring ">: "))
(if (/= (atof answer) 0.0)(setq #parof(atof answer)))
(princ line)
(setvar "pickbox" pckbox)
(setq ent(entsel "\nPick the line: "))
(setvar "pickbox" 2)
(setq point(cadr ent))
(princ line)
(setq side(getpoint "\nPick an offset side: "))
(setq dist(distance side point))(setq ang(angle side point))
(if(or(or(< ang 0.78)(> ang 5.5))(and(> ang 2.35)(< ang 3.92)))
(setq ang(- 0 ang))(setq ang(- pi ang))
);end if
(setq other(polar point ang dist))
(command "offset" #parof ent side ent other "")
(entdel(car ent))
(prin1)
