Author Topic: Make Sheet Index using obectDBX  (Read 71136 times)
Re: Make Sheet Index using obectDBX
« Reply #75 on: February 27, 2006, 03:55:44 PM »
What does the output list look like?  Once you have than, then sort it with vl-sort.  Post a sample returned list, and someone will be able to help better.
GDF
« Reply #76 on: February 27, 2006, 04:00:37 PM »
Thanks. Here is a typical output file.
Gary
« Reply #77 on: February 27, 2006, 04:04:37 PM »
I need to see the list.  Is it a list of lists? or does it just write to file from the code?  Let me look at the code one minutes.
I can't tell from your last post.
« Reply #78 on: February 27, 2006, 04:07:37 PM »
This is the output as of what is posted.
(("DWG" . "UTB30930")
("TAB" . "---  Layout1  ---")
("TAB" . "---  Model  ---")
("ROOM-NO" . "01")
("FINISH" . "2-1-1-1")
("ROOM" . "Entry")
("ROOM-NO" . "05")
("ROOM" . "Utility")
("ROOM-NO" . "04")
("ROOM" . "Kitchen")
("ROOM-NO" . "08")
("FINISH" . "2-1(2)-1-1")
("ROOM" . "Bath")
("ROOM-NO" . "06")
("FINISH" . "1-1-1-1")
("ROOM" . "Closet")
("ROOM-NO" . "03")
("ROOM" . "Dining")
("ROOM-NO" . "07")
("ROOM" . "Bedroom")
("ROOM-NO" . "02")
("ROOM" . "Living")
("ROOM-NO" . "12")
("FINISH" . "3-5-4-1")
("ROOM" . "Balcony")
("ROOM-NO" . "11")
("FINISH" . "3-6-4-3")
("ROOM" . "Storage")
("ROOM-NO" . "06")
("ROOM" . "Closet")
("ROOM-NO" . "06")
("ROOM" . "Closet")
("ROOM-NO" . "08")
("ROOM" . "Bath")
("ROOM-NO" . "07")
I changed the code to get this
 (("ROOM-NO" . "01") ("FINISH" . "2-1-1-1") ("ROOM" . "Entry"))
 (("ROOM-NO" . "05") ("FINISH" . "2-1-1-1") ("ROOM" . "Utility"))
 (("ROOM-NO" . "04") ("FINISH" . "2-1-1-1") ("ROOM" . "Kitchen"))
 (("ROOM-NO" . "08") ("FINISH" . "2-1(2)-1-1") ("ROOM" . "Bath"))
 (("ROOM-NO" . "06") ("FINISH" . "1-1-1-1") ("ROOM" . "Closet"))
 (("ROOM-NO" . "03") ("FINISH" . "1-1-1-1") ("ROOM" . "Dining"))
 (("ROOM-NO" . "07") ("FINISH" . "1-1-1-1") ("ROOM" . "Bedroom"))
 (("ROOM-NO" . "02") ("FINISH" . "1-1-1-1") ("ROOM" . "Living"))
 (("ROOM-NO" . "12") ("FINISH" . "3-5-4-1") ("ROOM" . "Balcony"))
 (("ROOM-NO" . "11") ("FINISH" . "3-6-4-3") ("ROOM" . "Storage"))
« Reply #79 on: February 27, 2006, 04:13:51 PM »
Lunch time, but here is code to sort the second list by room numbers.
(vl-sort
 (cdddr tmpList)
 '(lambda (a b)
  (< (atoi (cdar a)) (atoi (cdar b)))
Where tmpList is the list.  Here is the output.
Command: (vl-sort
(_>  (cdddr tmpList)
(_>  '(lambda (a b)
('(_>   (< (atoi (cdar a)) (atoi (cdar b)))
('(_>  )
(_> )
((("ROOM-NO" . "01") ("FINISH" . "2-1-1-1") ("ROOM" . "Entry")) (("ROOM-NO" .
"02") ("FINISH" . "1-1-1-1") ("ROOM" . "Living")) (("ROOM-NO" . "03") ("FINISH"
. "1-1-1-1") ("ROOM" . "Dining")) (("ROOM-NO" . "04") ("FINISH" . "2-1-1-1")
("ROOM" . "Kitchen")) (("ROOM-NO" . "05") ("FINISH" . "2-1-1-1") ("ROOM" .
"Utility")) (("ROOM-NO" . "06") ("FINISH" . "1-1-1-1") ("ROOM" . "Closet"))
(("ROOM-NO" . "06") ("FINISH" . "1-1-1-1") ("ROOM" . "Closet")) (("ROOM-NO" .
"06") ("FINISH" . "1-1-1-1") ("ROOM" . "Closet")) (("ROOM-NO" . "07") ("FINISH"
. "1-1-1-1") ("ROOM" . "Bedroom")) (("ROOM-NO" . "07") ("FINISH" . "1-1-1-1")
("ROOM" . "Bedroom")) (("ROOM-NO" . "08") ("FINISH" . "2-1(2)-1-1") ("ROOM" .
"Bath")) (("ROOM-NO" . "08") ("FINISH" . "2-1(2)-1-1") ("ROOM" . "Bath"))
(("ROOM-NO" . "11") ("FINISH" . "3-6-4-3") ("ROOM" . "Storage")) (("ROOM-NO" .
"12") ("FINISH" . "3-5-4-1") ("ROOM" . "Balcony")))
« Reply #80 on: February 27, 2006, 04:53:12 PM »
Thanks for the input Tim.
GDF
« Reply #81 on: February 27, 2006, 05:04:35 PM »
Allen and Tim
Thanks. Perfect. This will give a good example to learn from....but right now my head hurts.
Gary
« Reply #82 on: February 27, 2006, 05:16:10 PM »
Sorry didn't have time to make it look purtty.  You're welcome.
Allen and Tim
Gary
You're welcome also, for what little I did.
« Reply #83 on: February 27, 2006, 05:18:31 PM »
Just a little FYI...
The sorting code I posted may stumble if you have rooms with the same number, but have a letter at the end because I turn them into integers to sort, found out that it works better that way.  If you have letter/number combinations you might want to test it out how it is, and without the changing them to integers part.
GDF
« Reply #84 on: February 27, 2006, 05:21:42 PM »
So far everything works great. It will always be numbers.
Gary
« Reply #85 on: February 27, 2006, 05:25:00 PM »
Was playing while you guys were posting and wasn't going to post, but, ...
Tim, I'd expected No's to cause problems too , but seems not .. ..
by
do you mean numbers or strings representing numbers ?
(setq dwgData (list "UTB30930"
                    (list (list "Entry" 01 "2-1-1-1   ")
                          (list "Utility" 05 "2-1-1-1   ")
                          (list "Kitchen" 04 "2-1-1-1   ")
                          (list "Bath" 08 "2-1(2)-1-1")
                          (list "Closet" 06 "1-1-1-1   ")
                          (list "Dining" 03 "1-1-1-1   ")
                          (list "Bedroom" 07 "1-1-1-1   ")
                          (list "Living" 02 "1-1-1-1   ")
                          (list "Balcony" 12 "3-5-4-1   ")
                          (list "Storage" 11 "3-6-4-3   ")
(setq header (car dwgData)
      Data   (cadr dwgData)
(setq NewData (vl-sort Data '(lambda (a b) (< (cadr a) (cadr b)))))
(setq NewDwgData (list header NewData))
("UTB30930" (("Entry"    1 "2-1-1-1   ")
             ("Living"    2 "1-1-1-1   ")
             ("Dining"    3 "1-1-1-1   ")
             ("Kitchen" 4 "2-1-1-1   ")
             ("Utility" 5 "2-1-1-1   ")
             ("Closet"    6 "1-1-1-1   ")
             ("Bedroom" 7 "1-1-1-1   ")
             ("Bath"    8 "2-1(2)-1-1")
             ("Storage" 11 "3-6-4-3   ")
             ("Balcony" 12 "3-5-4-1   ")
« Last Edit: February 27, 2006, 05:28:02 PM by Kerry Brown »
« Reply #86 on: February 27, 2006, 05:31:33 PM »
Sorry I should have said something sooner. I already had a sort going when Tim posted so I didn't look too hard at it.
If you look at the file you'll see it.
  (defun srt (data / e1 e2)
    (vl-sort data '(lambda (e1 e2) (< (cdar e1) (cdar e2))))
« Reply #87 on: February 27, 2006, 05:40:40 PM »
<snip>
by
< snip >
BTW : String or numbers each work for the sort.
« Reply #88 on: February 27, 2006, 05:41:11 PM »
It would be strings representing numbers because they are gotten from attributed blocks.
All good Alan.  I just wanted to state that incase someone looks later at it.
FYI...
You don't have to make the variables "e1" & "e2" local to the function because they are already local to the lambda function.
« Reply #89 on: February 27, 2006, 05:50:28 PM »
Good point. Thanks
