Author Topic: Layer filter delete with filter  (Read 8193 times)
Re: Layer filter delete with filter
« Reply #15 on: March 01, 2006, 06:58:33 PM »
Off topic, but ... if you invoke the vla-GetExtensionDictionary method on an entity / object that does not have an extension dictionary said method will add one -- undesirable behavior in most situations. In these situtations it is better to test and conditionally retrieve the extension dictionary --
i.e.
(if (eq :vlax-true (vla-get-HasExtensionDictionary object))
        (setq xdict (vla-GetExtensionDictionary object))
We now return you to your regularly scheduled discussion ...
« Reply #16 on: March 01, 2006, 07:06:30 PM »
and not trying to tag team you ..
Using something like this is a little safer than just using (vla-item obj index)
(defun k:AssertItem (collection item / returnvalue)
    (not (vl-catch-all-error-p
           (setq returnvalue (vl-catch-all-apply 'vla-item (list collection item)))
     returnvalue
« Reply #17 on: March 01, 2006, 07:31:29 PM »
Thank guys...my brain hurts now.  :-)
« Reply #18 on: March 01, 2006, 07:45:17 PM »
Relatively simple < the routine, not "Hurting your head" ;) >
Just replace the call to vla-item with k:AssertItem using the same parameters.
The routine will return either the Object related to 'item' or NIL.
.. bypassing the possible dummy-spit in the instance where the 'item' translation errors out.
added:
This could , of course, be written in line each time ... but I type slowly, so ...
