Author Topic: adding a prefix to many existing attributes  (Read 4797 times)
ELOQUINTET
« on: October 10, 2005, 09:57:52 AM »
i have a location plan which has alot of numbered motors. it has been suggested to me that it would be better to number my motors by floor. so my attribute would need to change from 16 to 2.16  . does anyone have something that could do this?
David Hall
  • Automatic Duh Generator
Re: adding a prefix to many existing attributes
« Reply #1 on: October 10, 2005, 10:12:09 AM »
I could do it in VBA if you want
LE
« Reply #2 on: October 10, 2005, 10:22:40 AM »
Here is a good start:
http://www.theswamp.org/forum/index.php?action=search2
It may be there something already done...
Good luck.
ELOQUINTET
« Reply #3 on: October 10, 2005, 10:38:54 AM »
i found this topic which i think will do what i want. i modified it but can't get it to work. what did i do wrong? CmdrDuh refresh my memory how do i load vba  :lol:
http://www.theswamp.org/forum/index.php?topic=3813.0
here's the modified code:
(defun c:attpref (/ ent entlist newnext newnum newpre next)
 (if (not *num*)(setq *num* 1))
 (if (not *numpre*)(setq *numpre* "A"))
 (setq newpre (getstring (strcat "\nMotor prefix (" *numpre* "): ")))
 (if (not (eq newpre ""))(setq *numpre* newpre))
 (setq newnum (getint (strcat "\nNumber to start with (" (itoa *motnum*) "): ")))
 (if newnum (setq *motnum* newnum))
 (while (setq ent (car (entsel "\nSelect next lateral: ")))
   (setq entlist (entget ent))
   (if (and (eq (cdr (assoc 0 entlist)) "INSERT")
   (= (cdr (assoc 66 entlist)) 1)
(setq next (entget (entnext ent)))
(setq newnext (subst (cons 1 (strcat *numpre* (itoa *motnum*))) (assoc 1 next) next))
(entmod newnext)
(entupd (cdr (assoc -1 newnext)))
(setq *motnum* (1+ *motnum*))
and here's the result i get:
Command: attpref
Motor prefix (A): 1
Error: bad argument type: fixnump: nilundo Current settings: Auto = Off,
Control = All, Combine = No
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
<1>: end
David Hall
« Reply #4 on: October 10, 2005, 10:57:48 AM »
I screwed that up, so I rewrote it, and posted it here
David Hall
« Reply #5 on: October 10, 2005, 10:59:27 AM »
you will need to edit the block name, and the tag name, and what floor you are on.  vbaman, load the dvb,   Alt-F8 to choose the macro
ELOQUINTET
« Reply #6 on: October 10, 2005, 11:29:31 AM »
not sure which are the block and tag names in your code  :oops:
David Hall
« Reply #7 on: October 10, 2005, 11:31:54 AM »
edit here
    Set objSelSet = objSelCol.Add("Motor")
    intType(0) = 0: varData(0) = "INSERT"
    intType(1) = 2: varData(1) = "MOTOR" ' <------Block Name edit here
    For Each objBlkRef In objSelSet
        '        If objElem.EntityName = "AcDbBlockReference" Then
        If objBlkRef.HasAttributes Then
            varArray1 = objBlkRef.GetAttributes
            For intCount = LBound(varArray1) To UBound(varArray1)
                Select Case varArray1(intCount).TagString
                    Case "000"   '<------ Tag name edit here
    strNewAttribute = "2." & strOldAttribute  '<------ what floor are you on
    TagStringEdit "MOTOR", "000", , strNewAttribute    '<------edit blockname and tag here
David Hall
« Reply #8 on: October 10, 2005, 11:34:21 AM »
If you are still having problems, post your block, and I'll update the code for you.
Murphy
« Reply #9 on: October 10, 2005, 12:32:41 PM »
Why not just prompt for the floor number?
Dim flr As String
flr = InputBox("What floor are we working on?", "Floor Number", "1")
strNewAttribute = flr & "." & strOldAttribute
Bob Wahr
« Reply #10 on: October 10, 2005, 12:37:30 PM »
why not just
Command: -ATTEDIT
Edit attributes one at a time? [Yes/No] <Y>: N
Performing global editing of attribute values.
Edit only attributes visible on screen? [Yes/No] <Y>: N
Drawing must be regenerated afterwards.
Enter block name specification <*>: specify blk name if you need to
Enter attribute tag specification <*>: specify attrib name if you need to
Enter attribute value specification <*>:
170 attributes selected.
Enter string to change:
Enter new string: 2.
David Hall
« Reply #11 on: October 10, 2005, 12:54:10 PM »
would that append the 2. to the motor number?
Bob Wahr
« Reply #12 on: October 10, 2005, 01:26:35 PM »
It would place 2. before the existing attribute which is what he's going after.
ELOQUINTET
« Reply #13 on: October 10, 2005, 04:10:52 PM »
HEY GUYS SORRY HAVEN'T BEEN KEEPING UP WITH THE CONVERSATION. damn caps lock. anyway i found my own solution. i had a lisp which accomplished what i wanted to do after all. i'll post it when i get a moment under the gun now
hudster
« Reply #14 on: October 11, 2005, 03:50:38 AM »
You could do this easily using the find command, under options though, make sure you only select the attributes option.
Sometime there are easier ways  :-)
