Author Topic: broke (Lee Macs) ScriptWriterV1-2.lsp  (Read 473 times)
Lonnie
« on: May 16, 2024, 04:46:27 PM »
I was attempting to run off a UNC and I crashed my modified lisp. I now can not get his original to run (Even when I download a new file). It loads fine but here is what happens.
Command: WSCRIPT
** Error: bad argument type: stringp nil **
I went so far as to remove autocad from my registry and recreate it. Still no joy.
I also tried setting all the local vars back to ""
Re: broke (Lee Macs) ScriptWriterV1-2.lsp
« Reply #1 on: May 16, 2024, 06:06:49 PM »
Try removing the corresponding LMAC_ prefixed files from the Support folder under ROAMABLEROOTPREFIX.
I must say the program is old and in dire need of improvement  :|
Lonnie
« Reply #2 on: May 16, 2024, 06:39:06 PM »
Tell me do you ever get tired of thanks?
(getvar 'ROAMABLEROOTPREFIX)
"C:\\Users\\lshaw\\AppData\\Roaming\\Autodesk\\AutoCAD 2025\\R25.0\\enu\\"
Removed
LMAC_WScript_V1.2.cfg
LMAC_WScript_V1.2.dcl
Reloaded and it works.
Thank you.
Double thank you.
"\\\\DT-LSHAW2\\dcapps"
works just fine in the cfg file.
PS it may be old but it's still a great tool
« Last Edit: May 16, 2024, 06:47:59 PM by Lonnie »
« Reply #3 on: May 17, 2024, 06:29:01 PM »
You're more than welcome Lonnie - I'm delighted that it's still proving useful!  :-)
