Author Topic: Launch pdf from sharepoint without invoking an internet program.  (Read 346 times)
Lonnie
I have lsip that opens Microsoft Edge and then launches my default PDF reader using a function called. Here's the code
(If someone knows who should get credit for this I am more than willing to remark it
(defun launchpdf (pdfname / shell)
  (setq pdfname (vl-string-translate "|" "\\" pdfname))
  (setq shell
        (vla-getinterfaceobject
          (vlax-get-acad-object)
          "Shell.Application"
  (vlax-invoke-method shell 'Open pdfname)
  (vlax-release-object shell)
(defun c:cheats ()
  (launchpdf "https://teams.company/revit//revitblog/PublishingImages/New%20user%20Packet/cheatsheet.pdf")
However, I'm encountering an issue with hosting a PDF cheatsheet on our company server. Currently, I'm only able to access it via an HTTPS link. Is there a workaround to enable me to keep the cheatsheet on our company server? If I launch the pdf off my computer it works the way I want.
(defun c:cheats ()
  (launchpdf "\\\\dt-lshaw2\\dcapps\\help.pdf")
Unfortunately, IT has been unable to provide a non-HTTPS link. Any suggestions on how to resolve this would be appreciated."
BIGAL
  • 40 + years of using Autocad
Re: Launch pdf from sharepoint without invoking an internet program.
« Reply #1 on: May 10, 2024, 10:16:27 PM »
Seem to remember open a pdf direct just like this (startapp "notepad" "D:\\acadtemp\\test.lsp")
Something a simple as (command "_start" "D:\\acadtemp\\newblock-02.pdf") Worked in my Bricscad.
Lonnie
« Reply #2 on: May 13, 2024, 12:31:34 PM »
Same result. It tries to open the link
in edge then launches bluebeam.
If I do it with a unc I am fine.
« Last Edit: May 13, 2024, 04:52:15 PM by Lonnie »
CodeDing
« Reply #3 on: May 13, 2024, 07:11:56 PM »
Lonnie,
Try this help article from Bluebeam:
https://support.bluebeam.com/articles/revu-open-pdf-from-browser/
Best,
~DD
Senior CAD Tech & AI Specialist
Need AutoLisp help?
Try my custom GPT 'AutoLISP Ace'
