Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Check if clip is present in the drawing
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Check if clip is present in the drawing (Read 1535 times)
w64bit
Newt
on:
April 27, 2024, 08:37:38 AM »
How I can check if a drawing contains clip?
ssget can help? If yes, someone knows if there is a group code for clip?
Last Edit: April 27, 2024, 11:53:41 AM by w64bit
Logged
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Re: Check if clip is present in the drawing
Reply #1 on:
April 29, 2024, 03:33:22 AM »
in the whole drawing? it's a Spatial Filter right?
this is python, maybe it can give a hint
Code - Python:
[Select]
import
traceback
from
pyrx_imp
import
Rx
Ge
Db
Ap
Ed
def
PyRxCmd_doit
None
try
db
Db.
curDb
print
len
db.
objectIds
Db.
SpatialFilter
desc
except
Exception
as
err:
traceback
print_exception
err
Logged
https://github.com/CEXT-Dan/PyRx
https://pyarx.blogspot.com/
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Reply #2 on:
April 29, 2024, 03:37:05 AM »
I found this
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/groupcode-for-an-xclip-or-how-to-access-it/m-p/856189
Logged
xdcad
Swamp Rat
WWW
Reply #3 on:
May 02, 2024, 05:21:12 AM »
CLIP information is stored in the extended dictionary of the AcDbBlockReference (INSERT) object,
The Inspector tool can view
You can traverse all INSERTs to determine whether there is ACAD_FILTER
Code - Auto/Visual Lisp:
[Select]
defun
XD::Doc:HasFILTER
SS i bFound dict
if
setq
ss
ssget
"x"
0
"Insert"
progn
setq
i
1
bFound t
while
and
bFound
setq
e
ssname
ss
setq
i
1+
i
setq
ed
entget
e
if
and
setq
dict
cdr
assoc
360
ed
cdr
assoc
3
entget
dict
"ACAD_FILTER"
setq
bFound
nil
not
bFound
Last Edit: May 02, 2024, 05:26:54 AM by xdcad
Logged
https://github.com/xdcad
http://bbs.xdcad.net
w64bit
Newt
Reply #4 on:
May 08, 2024, 11:43:07 AM »
Thank you.
Is it possible, please, to add an alert when xclips are found?
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
